XRAY T3
#2701
Woop just won this. Not bad a i think for 400 bucks. New car, couple spurs and pinions and a set of cs27. Car was partially assembled but never run. Not bad right?.
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
#2702
Also i never seen anything about a orange edition. I imagine this was just something the seller added. Anyone can confirm?
#2704
I think theres alot of different things that would come into play here though also. You run thicker oil and less droop so your car would roll less then mine does. Obviously you dont like the idea of lifting the motor mount but im going to mess with it. Everyones car in 17.5 (I think were the first in mod to have them?) that has a exotek chassis go look at there motors, especially Brian's car, his motor looked worse then mine in mod lol. That cant help corner speed
#2705
Can anyone point me in a good med traction asphalt setup? Got my first race with the xray on sun.
#2706
hey guys,
just a small question
we have 4 T3 in our track and they all share the same problem, when you lift the car on a stand and accelerate about 1/4 of the throttle or even less and turn the wheels while still on throttle, the front end vibrates like crazy!!! we changed shafts, bearings, wheels but the problem still exists. am running a T2 and i dont have the problem at all.
when we put the T3s on the track, they seem to be fine without problems, the vibration is there only when the car is lifted and wheels are turned.
just for info, all cars have solid front diffs.
cheers
Ali
cheers
Ali
#2707
hey guys,
i have few question and a proble.
ill start with the problem.
my questions are regariding the shafts, the kit comes with thick and thin shafts, if am not mistaking, the thin goes in the back and the thick ones goes upfront!! am i right???
part numbers are 305326 (rear EU)
305324 (front EU) taking from the T3's exploded view.
but when i check the parts on amain, you can tell by the picture that the 326 is thicker than the 324. am a bit confused and needs an answer asap because i have to order them from amain.
cheers
Ali
cheers
Ali
#2708
thanks for the answer,
i edited my post and deleted the whole thing about thin and thick because i went through the manual and saw the steel vs alu thing and realised that thins go upfront and thicks go in the back.
will the ECS solve the vibration problem??
cheers
Ali
cheers
Ali
#2709
Team EAM
cheers
Ali
cheers
Ali
They are expensive but with a spool its almost a must have.
EA
#2710
cheers
Ali
cheers
Ali
Skiddins
#2711
cheers
Ali
cheers
Ali
#2712
Stay on top of the maintenance of the ECS driveshafts (the setscrews and pins) or you will be replacing them more often than you should. I check the setscrews after every run to make sure they're tight. A little shrink wrap over the coupler body helps keep the pins in if the set screws loosen.
#2713
So what upgrades does everyone consider must have on the t3. I ran about 6 packs today at a local carpet track that is opening up next week and it help up great. Took a couple hard hits as i was learning the car and getting it dialed in.
All i broke was a steering block. Might upgrade to aluminum. What else should i consider. Also does anyone have a great setting setup that everyone goes by. Ran it box stock with a couple changes and got it to feel ok for the first day but still didnt feel like my corally. Thanks guys.
#2714
#2715
thanks for the answers quys.
Ali
Ali
