XRAY T3
#2101
If the aluminum hubs are using the plastic reducers you have to run the smaller bearings and the orginal stock bearings that are used in the plastic hubs will not work in the aluminum ones. At least thats the deal with the stock Xray pieces.
#2102
What chassis weights do you guys use to balance out the t-3???
#2104
Does xray make any weights that would work with the t-3??? I remember seeing a set for the 009 but not sure if it would work for the t-3
#2105
punkboy and johnny wishbone: thanks for the input and advice
#2106
#2107
#2109
Daz, the 664 are used on the L1/L2 roll centers as they have the little dot molded into them and that is meant to be mounted one way not the other. The 663 are used everywhere else on the kit.
What you really want is these
http://www.teamxray.com/teamxray/sho...b0b3a96ea2ae42
#2110
mag wheel tyre balance weights (the shiny ones, not the lead looking ones)..
i purchase these for $1-$2 per strip of 60gm weights (4x10gms,4x5gms)..
they also come with pretty damn good double sided tape pre-mounted to them so they are ready to use..
these are purchased locally from "Tyre Power" but i'm sure most tyre fitters have these
-Mark
-Mark
#2113
has anyone tried these yet?
it's being sold at nexusracing and produced by team epic/trinity as per the website indicates.
http://www.nexusracing.com/product_i...0f623d81a1a78e
It does not state, however, what size bearings it uses, but based on the picture, it seems like the stock ones.
#2114
#2115
thanks for the info guys about the weights!!!
