XRAY T3
#2071
#2072
+1 would also like to know how good it is compared to exotek???
#2073
i am looking for help after todays testing
i was on a tight technical track today and although the car drove well i could do with i little more steering , i was on full lock though the infield a lot and i feel i could do with some more steering and a little more rear grip all though i think the LTC-r body was not helping the rear grip , but i was struggling for steering with the Speed6 body
would making the car narrower at the front help ??
this was my set up from the the end of the day i changed a little due to lack of time.
any help would be nice cheeRS Phil
http://forum.teamxray.com/xform/inde...=1497&setup=t3
#2077
#2078
#2079
#2080
#2082
has anyone tried these yet?
it's being sold at nexusracing and produced by team epic/trinity as per the website indicates.
http://www.nexusracing.com/product_i...0f623d81a1a78e
It does not state, however, what size bearings it uses, but based on the picture, it seems like the stock ones.
#2083
R/C Tech Elite Member
Add two screws back into the rear top deck - either in the wings or topdeck. If there is no grip use even softer springs. I had to run 2.4 in front and yellows in rear on a pollen filled track this weekend.
Offset your ride height - make the back 0.5mm higher
Shim up the front camber link to 2mm from 1.5
Add a 1mm shim under the outer knuckle/steering rod link
Reduce rear toe to 2.5 or 2
#2084
Skiddins
#2085
What is the diff ball size for the t3? The instruction manual says 2.4mm, is this right or is it a 3/32. I am looking at ordering ceramic from avid and that is the closest i can find at 2.381mm.
