RD/Richey Racing Engine
#496
Originally posted by Motorman
To those who are concerned. The signature engines should be at rd in 22 days. They will be based on a different engine base than the techwell but are the real deal. Been alot of juggling going on. They are truly customs and there will be no more signatures (the signature will be a short rod motor) for a while, while we work on a second generation engine for next year. we will launch a great motor that is custom made to our specs for us in the next month.(the engine the signature is based on)that is within 95% performance of the signature. extensive testing has gone on and our versions really run exceptional for the dollar value. I'm a really fussy when it comes to my blessing and putting my name on it.
AFM
#498
Motorman- Maybe if you and your crew dont pump up these motors so much there would not be so much expectation. Just test quietly without the fan fare. That way a problem with your motors does not look like such a big problem. I've been reading your thread and it seems you have said that the motors should have been here already.
I think if you look at the lap times of Haras car they do not show a lack in power as Motorman said. His lap were all just as fast as Blackstock and Swuager even if they seemed to look faster. Hara is very smooth and accurate and never upsets the car by over powering the tires like everyone else.
Check out the times at the http://www.jlapracemanager.com/cgi-b...ATE=09_03_2004
#499
actually I have not seen any of my crew making any posts in regards to the engine in a long time. However I do owe an explanation and or a timeline to customers who have inquired about the engine as numerous issues similar to the ones I believe killed the odonnell motor we have been required to deal with. If there is hype thats not what I'm looking for. If I share in my enthusiasm and it is construed as hype your taking it the wrong way. If you consider a tuned pipe being to short a big problem.
non sigs will be available at the same time.
If you want the entire lowdown on what is what you guys tell me and I'll get into all the nitty gritty. All our testing is done and finished. Production is another issue.
Rangulo I was there were you? hara's driving made up for a lack of power. He was not lacking much maybe 5% but you could definatly see it on the track. Now maxy has given an explanation for that and as cool as the engine was I can see why it lacked top end. Since he is the engine builder he should know. Bottom line was he was short on overall power. I marshalled the race at the end of the back straight and Swauger would gain 5 car lengths on him there and Hara would make up 4 in the infield.
#500
<SNIP>
<SNIP>
Anyone undertaking the design and production of a brand new engine is bound to encounter hurdles. Some of these hurdles will, and have, pushed back the scheduled release time.
Personally, I appreciate the refreshing honesty of being kept informed of the progress status. This is a whole lot better than being given some "feeble excuse" by a faceless marketing person.
Just my $0.02 worth.
#501
or sold somthin thats still not right!!
#502
#503
I hope that your motors do all the things that have been said on this thread. The market does need a lower costing entry level motor to offset the nova line. It seemed to me that before the nats the people on this thread were so hyped up about the RD line and it all Fizzed away after the nats. Because of all the hype I went to the Nats expecting to see this awesome little candy colored motors who could run for like 8 minutes on a tank.. Maybe the run time is a little overdone but some crazy number like that was said to be the run time on one tank.
I did go to the nats. I sat close to one of your drivers who yanked the RD motor from his car becuase it would not run correctly. He than put in a Mugen X12 in his car!!! You remember that?
#505
Driver your talking about would be Eli Ezrow. Eli had zero time prior to nats to run the engine and had to run a proto one hand machined engine thats two years old because we had a catastrophic crank failure in one of the 11MM proto twos. I knew after one round that that engine was not going to be a serious player. This is the reaon we wer also testing the proto threes with the 12 mm cranks which is production intent. 0 crank failures to date. The bottom line is I only had 7 motors to work with at the time and we wanted to fill the field with as many as possible to get a good gauge. I think we accompolished what we set out to do regardless of where the guys finished.
As for 8 minutes it was achieved and several people whitnessed it. however it was cool weather on a lower bite track. would I expect that, not really however in many cases even at the nats depending on the car many of the drivers came in with 20 cc or better left in the tank.
I was hyped and still am despite many setbacks. If I could just get the manufacturer to produce it would be all good. As of this moment we are discussing moving the entire version of this engine to another manufacturer we know can produce the quality and numbers we want. (READ HERE THE DEVELOPMENT IS COMPLETLY DONE) This will set this version of engine back slightly.(one more time. Read add more gray hair) On another note I have been testing another manufacturers engine we intend to distribute with our own parts inside. The performance has been good with the changes we have made and those are on the way. When you see them you will know them but they are different specs inside and some of the parts will be proprietary to us.
No excuses here just the facts
#506
Originally posted by 20 SMOKE
Any one have a link from the RD Logics race in CA. a few weeks ago
http://www.revrace.com/RaceResultsDi...04.txt&ID=1615
http://www.revrace.com/RaceResultsDi...04.txt&ID=1616
http://www.revrace.com/RaceResultsDi...04.txt&ID=1629
