Novarossi 421B
Novarossi 421B
NOVAROSSI "421" Turboplug Long Stroke 21. OFF ROAD S421BSX/1
Displacement 3.5 cm3
Maximum power 2.65 hp
R.P.M. (M.P.) 33.000 rpm
Practical Range 6.000÷ 38.600 rpm
Bore x Stroke 16.26 mm x 16.80 mm
Ports nr. 8
Piston type Die-cast
Crankshaft Ø 14 mm Crankshaft Type SG
Glow Plug Type Turbo
Exhaust Type Rear
How do you feel this engine? I intent to buy one. But in my club, no-one used it before.
Would you like giving me some ideas?
Thanks all!
Ports nr. 8
Exhaust Type Rear
Thanks all!
Tech Prophet
Ports nr. 8
Exhaust Type Rear
Thanks all!
Ports nr. 8
Exhaust Type Rear
Thanks all!
www.houstonsengineservice.com and read what i say about the 821b
Thank houston!
My friend, he said that 421B is better than 821B, is that right?
My brother had a 821b engine and it had been working very well untill now. And 421B has two kinds, one is turbo and another is standar, which is better?
Hix hix, i haven't used turbo yet so i don't know which can make my engine stronger.
turbo and standar, are they the same, not have different?
