Upgrade rc Wraps
depends on the skin...check out our website there's a bunch of examples
k, see the one on the main page? its a red, white, and blue design called Patriot
that body is painted all black
does it go on the inside or outside of the body. I am going to assume outside. which would lead me to believe that it won't last long. When i put decals on my buggy, no matter how much i clean it and press it one, In a couple of weeks the corners and stuff start peeling back Do thease work the same way. If they dont, i might wanna try it.
theres a ton of people using our stuff at all the tracks you go to in LA, have a look next time you're at a big race
they go on the outside of a brand new body, then you paint the inside to match
Wraps are the shiznizzle, I have paid for my last custom paint job. I have seen wraps that lasted 10+ gallons on a truggy, they actually help hold the body together. I reinforce my bodies with strappng tape on the underside and coat any areas that may rub the paint off with E-6000 (shoe goo, but cheaper and doesn't affect the paint)
My bodies usually last for a while-they are a little heavier but I am not adam drake so I can't tell
And on a side not they are better wraps than upgrade-my personal fav. Jab graphix they can also wrap all your gear to match(charger, power supply, radio, styarter box fuel bottle, glow ignitor and anything else you can think of
These wraps not only protect your body and make it last longer but the high quality of them looks great race after race!I have had one wrapped body on my 1/8th scale buggy all this year and after a wipe down and some spray wax and buff it looks just like new.It is a thicker material then the stickers you get with a kit therefore it is much more resistant to scratches.
little spray of Pledge and its good as new
