Yokomo Chargers?
I also was wondering about them... how is the temp charging feature? what are the + and - of these chargers? Thanks
The temp charge just shuts off the charger after the pack has reached a predetermined temperature via the included sensor. The only drawback, if you can call it that, is that they're just chargers. They don't discharge or run motors or anything else, just good chargers and the Double charger can charge two different packs at the same time
Back to the drawing board. Thanks.
the double is an awesome charger.. i also have the single.. but still need to sell it. the great thing about these chargers is the timer feature.. i just set the timer and i can go turn marshall or work on my car without having to worry about starting up the charger.
randman is right.. get the rayspeed disc. and your all set. i have it and use it combined with my chargers and it works great.
one thing tho.. for the double.. found this weird error. it would charge a battery up to 7-10mah.. then stop... and give me an E.. instead of an "M" reading. i unclipped the aligator clip..and clipped it back on..and worked fine. probably a glitch in the system
BCS Double = plastic case
