New Team CRC Gen-XL
#271
Ian Ruggles is having some computer issues and asked me to post his set-up from the Halloween Classic. He Qualified 5th and finished 2nd in 17.5.
.45 fronts
10 degree blocks
10,000wt lube on the kingpin
brace, short arm
all shims back
1 degrees camber
servo up
Magenta Front 1.55 (No Glue)
Red Center spring
White Sides, Just touching the pod plate
35wt oil in shock
10,000wt in the tubes
Yellow Rear 1.67
Batteries back
CD Wells
.45 fronts
10 degree blocks
brace, short arm
all shims back
1 degrees camber
servo up
Red Center spring
35wt oil in shock
Yellow Rear 1.67
Batteries back
CD Wells
#272
I'm having a problem with the steering links hitting the servo case when turning. Since the links need to be run on the inside of the servo saver, every time I turn the links touch the servo case. I think it may be a servo saver problem, what servo saver are you guys running? btw this is with a futaba 9650.
#273
Trev
#274
does it mean the servo is at the top of the angled support?
or does it mean the servo horn is up because the servo body is mounted flat on the chassis?
#275
the lube is a less drastic change than a side spring. Lighter lube will cause your car to be less aggressive, heavier lube will cause the side to side motion to more aggressive. quicker through chicanes... It effects how fast the rear of the car rotates.
#276
#277
Fitting a Futaba 9650
I think I've tried every single combination possible in trying to fit a futaba 9650 to this car in order to A not hit off the servo and B not hit off the caster blocks or the front graphite brace if fitted.
Final solution, using a small servo saver. Use the trailing graphite steering arms that are fitted to the GEN X, mount the servo mount in the furthest forward hole, use a 1 mm spacer not the kit spacer between the servo and mount. Finally most importanty make sure when you attach the servo you pull it as far up the mount as possible and then secure it.
If you mount the servo on the forward holes and then use the kit spacer the steering rods will hit the case. If you let the servo slide down the mount then the steering rods will hit the graphite brace and if you have the spacer, the kit arms and the servo down then it will hit the caster blocks.
Took me far too many hours to get that sorted.
Kenneth
Kenneth
#278
Fixed
#279
my son and I just finished building ours, cant wait to get all our electronics, and get this on the track. haven't raced in like 6 years
#280
Advanced Electronics ESC
So I see CRC has the new ESC's on pre order. Does anybody know anything about them like what is included with the hefty price? Does it come with a capacitor or a programmer. For that matter what do you use to program the ESC and is the software upgradable. I am just curious to know more about the Black Box.
Thanks!
Thanks!
#281
Thanks!
Thanks!
#283
Thanks!
Thanks!
