Question about TC3 steering racks
The steering rack on my TC3 always seems to get very rough in its movement. I've taken it apart a number of times now and cleaned all the parts but after a few runs its all sticky again. It seems pretty free at the ends but near the center points is where I seem to have the most trouble. As a result, the car has trouble re-centering after a turn. Is this to be expected with the TC3 steering or is there some trick I'm missing? I race exclusively on carpet so, dirt from asphalt should not be an issue. Pulling out the steerng rack and cleaning it is a bit of a pain so I'd like to avoid having to do it all the time if possible.
No digital servo. My car is pretty much stock RTR so I still have the crappy Hi Tech servo that came with it.
Yeah, Hitec servos are notorious for having centering problems.
OK so, I need a new servo. With a new servo would the slight stickness in the rack be less of an issue?
We have been having some simular TC3 problems. What is the feeling about a JR Z590M would that be a good replacement? for a rookie learning to drive ( IE hitting stuff)
Thanks, Sam
Thanks, Sam
the rack is kind sticky unless you prep it.i cut out all the burrs and then i polish the inside with mothers plastic polish by using a q-tip in a cordless drill.it may take a little while but it is smoothe as glass when you are done.after you do this you should be able to just blow the rack out with some compressed air.hope this helps
Re: Question about TC3 steering racks
don't oil the bearings it will attrach anykind of dirt. also tighten the servo saver all the way down and cut the excess thread off the bolt so it won't rub the shaft then put a drop of CA in it.
I had a similar problem with mine. Check the black nylon nuts that hold the bushings down, even if they are just a TAD too tight it will cause that to happen. Fixed my car, good luck!
The jr 590m is a great servo for that app. Plenty of power very strong gear train and it centers well. The only problem is its slow but for the money you cant beat it.
