Ofna truggy starter box - rewire for Lipo?
I've also been considering switching my Ofna truggy box over to Lipo. My question is....do you need some type of low voltage cut off like you do on the electric cars/brushless set ups? How do you monitor voltage and know when to recharge the battery before it gets dangerously low?
kept mine stock works great for year now
OK, I just want to be certain I'm doing this correctly:
1) Replace ALL wire with good wire (deans wet noodle)
2) Replace all connectors with deans type
3) Remove switch connectors and solder directly
4) Remove motor connectors and solder directly
Did I get this right?
Thanks everyone
Thanks everyone
Thanks everyone
Thanks everyone
I had the same starter box, and used a losi starter box lipo just used the stock tamiya plugs never had any issues no voltage reg...just keep and eye on it if it starts to get slow dont use it until a re charge....with a properly tuned engine which will fire off right away I could go ruffly a mnth. on a chargeracing every weekend....
2 cool cheap item's i have for my lipo's and starter box is a basic cell checker and a battery monitor that has light's and will audibly warn you if the pack is getting dangerously low....and for under 15$ for the pair....there worth having around
Monitor
http://cgi.ebay.com/Maxpro-4S-Lipo-B...d=p3286.c0.m14
Tester
http://cgi.ebay.com/Li-Po-Battery-Vo...d=p3286.c0.m14
Monitor
Tester
