LPR vs. standard size tires? >
Old 08-14-2009, 02:33 PM
air8's Avatar
The VTR rims. Are they narrower and taller than the LPR rims?
air8 is offline
Old 08-14-2009, 02:39 PM
megasaxon's Avatar
Trader Rating: 25 (88%+)
VTR rims are taller, 4.0", vs LPR 3.7"
megasaxon is offline
Old 08-14-2009, 02:44 PM
air8's Avatar
Are VTR wheels same width as LPR?
air8 is offline
Integra's Avatar
Nope.....Bust out the caliper's and you'll be shocked as i was.....ALL LPR's are 4"......wacked as it may be....the caliper's wont lie....there may be 1-2mm of difference...but nothing like 1/4"
Integra is offline
Old 08-14-2009, 02:45 PM
  #20
Integra's Avatar
they are if anything 1/8-1/16 narrower then the AKA Ibeams i comrared them to......ill go see what they look like beside some Panther's...BRB.
Integra is offline
Old 08-14-2009, 02:52 PM
  #21
Integra's Avatar
Proof is in the Pudding there ALL 4"
Yellow is VTR
beside is AKA
then Proline LPR
then Losi Lightweight LRP
Forgot about width comparison...brb Air8
pretty obvious what treads they are.
Integra is offline
Old 08-14-2009, 02:56 PM
  #22
air8's Avatar
LOL. No prob. Thanx for posting that up buddy.
air8 is offline
Old 08-14-2009, 03:36 PM
  #23
megasaxon's Avatar
You are still wrong, the measurement on your LPRs needs to be from the base of the rim, not including the lip, VTRs don't have a lip like LPRs. inside diameter of LPR tires is approx 3.7" and VTRs are approx 4.0", LPR tirs would prolly stretch onto VTR rims, but not the other way around
Old 08-14-2009, 04:18 PM
  #24
air8's Avatar
Why wouldn't you measure from "tire/wheel across diameter to tire/wheel"? To me that's where the action of the tires starts from, so to speak.
air8 is offline
Old 08-14-2009, 05:52 PM
  #25
JSR
Trader Rating: 18 (100%+)
Thanks for the info guys.
Per Proline's site, the inner mounting diameter (where the bead is) is 3.7" for LPRs and 4" for VTRs. The outer/rolling diameter are approximately the same between LPR and VTR. And it seems VTRs are slightly narrower per Proline's site (and as can be seen in integra's pictures).
Jaz - I'll have to look into those AKA foams. I still have unmounted standard size tires which would probably greatly benefit from better foams. The stock foams are very soft.
Edit: corrected who posted the pics. Sorry.
JSR is offline
Old 08-14-2009, 06:07 PM
  #26
air8's Avatar
Actually it was Integra that posted the pics. Anyway, so that's odd that Integra comes up with same measurement for all the rims. It seems like Proline has picked a different spot to measure from. I must be overlooking something.
air8 is offline
Old 08-14-2009, 08:11 PM
  #27
megasaxon's Avatar
thats because LPRs, including the extra lip are 4.0", but where the tire actually glues, its only 3.7" the VTRs don't have that extra lip on the outside
see how there is no outer lip? its 4.0" total diameter. the LPRS 3.7" diameter, plus a lip of .15"
Old 08-14-2009, 09:01 PM
  #28
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
+1 they are measuring the mounting surface of the rims. Since the VTR's use a buggy style mounting bead, the rims are a different shape. Measuring from where the bead sits, the VTR rims will be taller. Measuring the very outside diameter of the rim's face, the measurement will be the same between LPR and VTR rims. They use totally different mounting beads so they are NOT interchangeable. VTR tires can only be used with VTR rims. VTR rims can only be used with VTR tires. That is without modification of the tire or rim.
JAMMINKRAZY is offline
Old 08-15-2009, 06:49 AM
  #29
Integra's Avatar
ok that makes seance i think.
but i still stand by my comment that they are Very Similar if not identical to the LPR in the handling dept...Proline Didn't re-Invent the wheel they just put a new spin on it.
Integra is offline
Old 08-15-2009, 08:29 AM
  #30
Performance wise they are close to the AKA tires, but far better than the proline LPR tires.
