3racing F109
#1441
Foams
is anyone else having trouble finding F103 foam tires????
I am trying to get some foam tires that are good on med/high grip outdoors but can't seem to find much at all. Any suggestions would be welcome as i haven't tried using foams before.
We run with silvercans and we are NOT allowed tire additives so it makes a tire choice a bit more critical.
#1442
You can either get them from Speedi Models in Auckland, or else get hold of Kevin Frewer if you just want some donuts to mount. His website is www.frewerracing.com
The phone number on the site is wrong, but the e-mail is correct.
#1443
I have no experience myself in that case, but if I had to run without additive, I would definitely look into nitro tires. Hardness apart, their composition is much better suited to situations where you can't use additive, partly because of their amount of rubber and size of the alveoles I think. For the right width you'll have to look for tires aimed at the now dead 235mm nitro class.
#1444
#1445
Hey guys I just picked up one of these cars and while I do like to read 97 pages is alot . My question, what are the most common and usefull mods that can be done to this car for better performance? I'll be using this for some p-lot racing and some limited carpet use also.
Chris
Chris
#1447
racing oprtional springs)
#1448
I'm going to bring it but I doubt I'll have it ready to run by then, just a roller right now.
#1449
Thanks, Mike
#1450
Speaking of the F104 diff. I am converting my F109 diff assembly to the F104, so you do not have to tighten the diff every time that you change tires, but if you look at the instructions it looks as though you have a bearing on each side of the spur gear between the inside and outside diff housings. Now I know that does not make sense, but it shows that in the instruction on the Tamiya and 3racing's instruction manual. I have attached a pic out of the manual.
Thanks, Mike
Thanks, Mike
Here is the Manual for the 104Pro. Page 5 is the diff instructions.
http://www.petitrc.com/reglages/tami...Pro_Manual.pdf
With the 64pitch gears, a bearing seats inside the spur gear (with a 48pitc hgear you don't use the bearing, but you need a small sleeve thing called a gear adapter). There is then a bearing on the spur side of the diff housing, a bearing on the wheel side of the diff housing, then the cone washers, the diff spacer and the diff nut.
The 3 Racing Outtuned diff is the same basic principle, and is cheaper, but in my opinion the f104Pro diff is the best. Ohh and in order to install both the 3racing Outtuned diff or the F104 pro diff you will need to either buy an F104 pro drive shaft, or you cna just cut your f109 drive shaft shorter.
#1451
No idea what car that is. Possibly the Wolf?
I appreciate it and beleive it not the pic I posted is from the F104, but not the pro version. Anyway, I appreciate your help very much.
Thanks again, Mike
#1452
Thanks, Mike
Thanks, Mike
The first bearing put on the axle fits inside the kit spur gear, Tamiyas metric spurs have much larger hole in them for this bearing, using standard 48 and 64dp spurs you use the thin POM plastic gear adapter instead.
#1453
R/C Tech Elite Member
Thanks, Mike
Thanks, Mike
When i went back to my 103 I took the 104 shock and diff with it, not my 103 is sound as a pound
#1454
The Tamiya F104 diff is really nice in that you don't have to reset the diff every time you change tires. However it does come with the draw back that setting the diff in the first place is more difficult as you can not make adjustments on the track. The 3Racing aftermarket diff for the F104 gives you some external adjustability but I find the adjustment ring doesn't work all that well and I end up adjusting it from the axle nut anyway. On the plus side the 3Racing F104 diff is extremely smooth and I will keep using it just for that alone.
#1455
Yeah, thanks, i've done that. If I reduce the limit any more, I won't make the hair-pins, i'm 3/4 track width at low speed as it is.
The question was more about the CRC parts. I already have them, so may have a play around with it over the next few weeks and see how it comes out.
