Palmaris engine thread
#2416
Originally Posted by uniquexme
is it true that BRB cannot be modified? Does the PR12 comes with modified linear and crankshaft and body? where can i get it, coz i would like to know how much it cost.
#2418
hello tommi, i am from sarawak.
is it true that the current palmaris and axial engines (both share similar technologies) are prototype only? when would the final products be launching?
#2420
hmm. how come there are different versions all around? but i heard that the only problem with palmaris is loosing high end
Used to be my problem to loosing high end power when I first switched to using the BRB 3-port from the usual outlaw 5-porters, keeping the same gearing and using the outlaw pipe. And then along the way tweaking with the engine tuning and settings of clutch and gearing, the Palmaris then gives me the power I need. In order to churn out the right power from different engines, choice of pipe, gearing and clutch is vital. Found out that going to 5.2mm/LEGAL pipe will give you more build-up pressure, and hence gives the high-end. The 2630 is a great pipe, but I'm currently using Max 2615 pipe with great success.
#2424
Does anyone knows the bearing size for Palmaris PR12? my frenz just got a this new engine, but doesnt want to open up his engine, so can someone advise wat bearing it use?
#2425
can someone tell me wats the difference between bi-metal and BRB? and wat does the stock PR12 comes with? BRB or Bi-metal?
Stock engine can be in both versions-BRB or Bi-metal-depend on preferences.
On the pic you can see the difference-right is bi-metal and left is BRB.
#2426
ok thanks for the bearing size, can i just check with u guys. Does the engine comes with box and instruction manual and glow plug? coz his engine doesn't comes with all these packaging. wat brand of plug can he use? coz i think he put a OS plug inside. thanks. btw, how much does this engine cost? m also thinking of getting 1 for myself.
#2427
ED you have PM
#2428
engine leaking oil
just got a PR12, love its powerful pick-up speed. However, there is this problem that cannot be fixed - engine leaking oil, so badly that at the end of the day, the whole car is covered with black oil. at 1st, we figure out its the caburator, coz there are these fresh nitro spitting out of it, just at the section between the cab and crankcase, so we use red silicon gasket, but it failed. then we replaced the whole carburator with RB's. at 1st, it seems all rite, but later, oil is leaking again, this time, we dunno where it came from. under chassis is filled with oil. has anyone face this problem?
another wierd thing with PR12 & BRB is that they have very inconsistance change of gear at straight road, coz my frenz BRB is also the same. His is even worse, need to lean up to 135oC before there is any true power. but for mine, other than oil leaking, its ok. just that top speed is also inconsistance.
oh can anyone post a picture of the PR12 caburator? coz mine do not have the palmaris logo on it (like for RB or OS, they have these engraved logo)
and last nite, after removing my engine and give it a good clean on the outside and some after run, i went to clean my car, then after tat, i noticed that there are still some oil at the crankcase (even when i put it on the desK). so can anyone help me? i m thinking if the crankcase is leaking, how can we see it?
#2430
guys, may i know wat con rod does this PR12 use? can we use Nova Con Rod? would like to ask the difference between PR12 and the Axial Green Colored heatsink engine, are they the same? thanks
Edward
