Mbx6 Fuel Tank
#31
Thanks man, i will give that a shot!
#32
Well ignore my comment about the driveshaft being too close....im an idiot and did not install the rubber inserts on the tank...good thing i have not raced it yet haha!... Now i see what everyone means about the top plate.
#33
never had one problem with mine. But i am going to try this stuff anyway
the fuel tank mounting is not very sturdy at all. I had to use longer screws in bottom and top. It got a little more sturdy. It strips out easy since it comes out my car more then anything else.
#34
Wanted to give an update of my exp thus far. So i increased the amount of presssure line i have on my car before i did anything else. I used about 7 inches of fuel line for the new pressure line. I started the car and let it get to about 180 degrees or so and then flipped the car over and it purred like a kitten instead of leaning out within a few seconds. The problem this past weekend is the car would lean out super fast when flipped over and then die once it got flipped back over. I think most peoples problems similar to this with the 6 is the pressure line because it was a new car compared to before when flipped over.
I also did the test where you dump the fuel when flipped over and then flip it back over, it ran for quite a while before dying and nothing eratic until the very end like usual.
