is it common practice to mix harder springs with soft ones? >
Old 08-01-2009, 07:26 AM
Default is it common practice to mix harder springs with soft ones?
I was curious if i could run 2 soft springs with 1 hard spring in my clutch. I have some new shoes and springs and the set of "new springs" that i just took off my old clutch (they have a couple tanks on them) they still have plenty of spring. So instead of installing all new 1.0 springs, thought i would mix some of the "lighter springs" with the new ones.
good idea or bad? seems like it would be the same as mixing .9 with 1.0 or 1.1
dreaux is offline
Old 08-01-2009, 07:35 AM
Shure, why not? It all comes down to finding what feels right to you.
The Working Man is offline
Old 08-01-2009, 07:39 AM
thanx. Just wanted to make sure i dont blow a shoe or something. Yes definitley like to try different. same ole = borring
dreaux is offline
Old 08-01-2009, 01:42 PM
Integra's Avatar
make sure to mark the spring's so you know which are "new" and which were "Newer"
as for mixing the spring rate's....100% fine...a lot of people do it...the stock losi clutch mixes spring's for the fact they run a carbon/alum mix for shoes....1 thing if you run a carbon set-up dont stall them over 1.0....if anything go 1.1 on the alum's first.
Integra is offline
