does anyone know how big the order will be
for the ninja's that will be coming in early august? I want to make sure i get one. The thing is i cannot place a order now while it's on backorder because i will not have my money together until the first week of august.
will there be enough to go around? Cannot find one anywhere right now. I am corresponding with someone that will hook me up when the time comes. Guess i am looking for some insurance.
BTW I was wondering if anyone had any comparrison from running an OS speed and the B01A Ninja engines. pros and cons besided the obvious 170 bucks??
I was thinking where have I been under a rock or something. That makes sense now. Its the new B01A with the lightened head. Ok I have noticed that they have been backordered for awhile.
IMO the Speed is not worth the extra money...Both make great useable power, but the JX has more grunt on the bottom. With the right clutch, pipe, and restrictor it is hard to tell the difference in the two on the track. I did not get great life out of my Speeds for whatever reason. My JX's however get well over 6 gallons usually without needing bearings or losing compression. Get the JX and put the money elsewhere..
What pipe do you suggest for the ninja in a 8t 2.0? Right now I have a mugen 2042 and L shaped header on the speed.
I am in the same position myself. Looking for a new engine. I had settled on the speed but decieded to go with the ninja because i have heard nothing but great things about them. I will be running mugen light weight aluminum shoes with 1.0 springs and a losi re11. Does this setup sound legit? might go ahead and get the ninja pipe and manifold. But only if i have to.
