XERUN V2.0 Brushless ESC discussion thread.
#616
Before this the Xe120A was on my son's RCGT HPI Sprint 2, running a Nosram 17.5T at FDR 5.25 (not the best choice, limited by our collection of pinions) with 231 fw. Since then my son has his own Xerun 60A, with 231 fw (no SC tested) for the moment. (Same huge track).
I have used the Xerun on the buggy only once (Lazer ZX5 std MK1 kit, with Trinity Pulse 6.5T), not sure what fw was on it then. Then installed the SP LPF 1.1 on the buggy and forgot about it!
On the ZX5 I run 76/20 gearing for our largish indoor track with no overheating probs so far...
#617
double post
#618
#620
is the stock capasitor sufficient for mod use?
#621
#622
#623
Dont see any real benefit.
If you want you can buy the option capacitor but i only see them working better when using the latest software and stock motors. In mod i havent noticed a difference. In fact the std caps i use on all my other esc's incl my Tekin RS Pro.
#624
aorry double post
#625
I used the XE120A with 205g running the 5.5T on the TC (Losi XXXS-G+). FDR is usually 5.66 but I managed to destroy the pinion grub screw, so in the last race I ran the finals with a bigger pinion giving FDR 5.13. I didn't like it that way, even though the track is huge!!!
this is the link to pics of our local offroad track for ep
http://takaduhung.blogspot.com/2009/...oad-track.html
#626
What is your track like? most of the off-road bugggies here uses 5.5t 10-12fdr.And it works well on then but my buggy is da only LRP S10 blast while the rest are on zx5, db-01's, and DF-03 MS.I still need more info on settings and fdr as i cant keep up with the other models paired to the same 5.5t sensorless.
The tracks are three: One indoor, largish, and two large primarily 1/8 tracks. We use shorter versions of them, but I m not sure what the fast guys use here...
#627
hi all, i have 2 questions
how i can update lcd driver (speed passion 1.2) to the hobbywing lcd? (1.4XXX)
In the xerun 60A, i can update software same as 120A not?
thanks to all, bye
thanks to all, bye
#628
HELLO:
There are all for modify motor ,the V1.10_091218a_t is the last version ,we will to release a new software for stock this day .
Thank you support hobbywing.
Best Regards!
Michael liu
Maybe he means "some day".But until today 04/22/2010 nothing.Hobbywing don't you think it's time to wake up?
#629
I made a mistake in the answer and I can not delete the post ...
However, this is the setup I used:
This track is very small and technical and you can see here:
http://www.automodellistivaldarnesi.it/
#630
hai agno, jst wanna to ask where u got the HW esc set-up sheet??
http://www.megaupload.com/?d=59RB4S77
