D8 Clunk fell of fuel line >
Old 07-15-2009, 07:29 PM
fievel's Avatar
Default D8 Clunk fell of fuel line
My clunk fell off of my fuel tubing inside of my tank. I dont have time to order a new tank so I took the tubing out of the tank and replaced it with new tubing along with the clunk filter cone thing. I had a hard time getting the fuel line back on to the plastic nipple with in the tank, i got in on there pretty good i think. now for the question, will the pressure in the tank when the car is running pull the fuel line on more if its not already on there all the way? thank you for your time.
fievel is offline
Old 07-15-2009, 07:41 PM
No. There's pressure, but not enough to put lines together.
Run losi line through the tank and eliminate the nipple all together.
Alan D. is offline
Old 07-15-2009, 07:42 PM
fievel's Avatar
can i just take off the black part that attaches the two fuel lines?
fievel is offline
Old 07-15-2009, 07:45 PM
Yeah. The nipple comes apart.
Pinch the nipple from inside the tank with your finger and loosen the nut on the outside of the tank. It's made out of plastic so be gentle. I've found that once you take it apart it leaks, so every time I get a new tank I jut eliminate the nipple completely.
Alan D. is offline
Old 07-21-2009, 11:09 AM
Jesse Robbers's Avatar
You can unscrew the black nipple and nut on the fuel line pick-up, it's plastic so don't grab it too hard. The internal fuel line can cut/tear from the klunk bouncing around and is usualy the cause of the klunk seperating from the internal fuel line. It wouldn't hurt to use a thicker fuel tubing for the internal line and possibly put an additional fuel tubing ring on it's end to pinch it onto the nipples better.
Jesse Robbers is offline
Old 07-21-2009, 11:28 AM
JPierson's Avatar
take off the top its only a e-clip & a pin its not hard!
JPierson is offline
Old 07-21-2009, 01:17 PM
fatdaddy's Avatar
+1. i do the same also.
edit: heres the link to main thread for the D8. http://www.rctech.net/forum/nitro-of...ies-buggy.html
lots of good help there, and it helps to keep the main list clearer.
fatdaddy is offline
