Who makes the highest quality engine?
#31
that would be similar the mugen making a ninja?? Yea, i don't know how i missed that.
I have a .26 picco that was RETARDED on the bottom. I think the jammin will even be better. THey have good longevity? are parts really expensive? Well i will go look at that myself. Hold on.
oh well the only part i found really was the rear bearing for 50$
#32
so i am down to a nova toro nerro, speed, jammin.
this will be difficult. But i don't think there is a wrong choice here. but i do want to make the right one.
#33
#34
#36
Did you get my PM.
#37
see you all tomorrow.
#38
nevermind. Replied your pm. And jazz, are you saying the jammin has more punch then the speed?
#39
No vspec running strong. Over the 5 gallon mark. Learned alot on this engine. Besides i want something new/ different. I know i could win with a vspec. And when it's all said and done might just get another vspec or speed. I think i want to stay away from a modded motor for the time being. But who knows when i might change my mind he he he
#40
the toro nerro looks very good. I don't really like the purple head, but that is nitpicking. It doesn't have a coated crank like the ninja or speed. but that is really not a big deal either as long as i can get 7 or 8 gallons out of it. Another thing, it says it has a single adjustable carb. It only has one needle? or it just doesn't have a mid range?
It doesn't have a ceramic bearing either. Should that matter?
#41
#42
i will have to continue this tomorrow. Bedtime. 4:30 comes early
#43
I agree, the only problem is that Nova's ceramic bearings cost a fortune. Easy solution, break it in with the stock bearings and once it's ready to race, drop in a set of TKO bearings and you're good to go.
#44
I really like the modified Picco/JPX engines....they tune easy,start easy,idle well they make wicked power and they last very well.. Picco uses great steel for the cranks so the crank pins rarely wear, as well the piston/sleeve seems to last an exceptionally long time, in many cases the engines will hold mechanical pinch for several gallons.... Picco plugs are also great quality and seem to last longer then any other brand I use... All in all for the money these are rock solid exciting to engines to run.... The performance is stellar, they sound nasty and have proven to be very reliable..... I do engines for many racers, tho you may not see me in the big events yet, there are dozens of average Joe racers doing wicked with my engines..My engines are tuned to have a strong punchy low end and a rippin top end, every time you clamp the trigger you will have a smile on your face ! . I am just a small company in Canada, but I am growing day by day one step at a time.......
Anyways here is a picture from the Canadian Winter nationals of the guys running my engines and their results...No big name racers yet, just average club guys out to have a weekend of fun..
#45
All are good choices, but honestly if you can afford it go with the speed all the way. The novas are great engines, but IMO don't make the power of the OS's. Also like you mentioned the cranks aren't coated, which is fine, but they WON'T last as long as a coated crank(not saying the engine itself, but the crank). Another downside is that they don't include a ceramic bearing, but that is simple to take care of with a set of TKO's. To me though, the biggest downside of the nova's is the high price tag on parts. Con rods can be up to $60. OS rods, even speed rods are no more than $45(not $75). You can also use a ninja rod in the speed(same rod) which will set you back less than $40. The jammin's are awesome engines, but simply don't get the fuel milage of the others. The OS is your best bet if you can afford it. It has an awesome powerband and great fuel milage. Can't go wrong with the speed...
