Locking center diff >
Locking center diff
Locking center diff
Old 07-15-2009, 11:20 AM
davidg01234's Avatar
Default Locking center diff
i locked the center diff on my 8 scale buggy it gave it really fast accleration but its hard to control is it bad to do that
davidg01234 is offline
Old 07-15-2009, 11:31 AM
token's Avatar
yes, now you have not slip, which give the ride stablity
token is offline
Old 07-15-2009, 11:34 AM
what do u mean no slip
Old 07-15-2009, 11:38 AM
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
LOL
Did you not think there might be a reason there is a center diff in your car.
JAMMINKRAZY is offline
Old 07-15-2009, 11:42 AM
Frank L's Avatar
Trader Rating: 148 (100%+)
Not advisable in my opinion. And why would you wan t to eliminate a tuning point on your car?
Frank L is offline
Old 07-15-2009, 11:43 AM
RJNicholson's Avatar
You may have gotten more forward drive, but now your center diff will not distribute power to the front or rear when you start to loose traction, or in off power steering.
If you want a fully locking diff get a smart diff or an active diff that you can fit into your ride. This way it unlocks on off power like it needs to so you get an even distribution of power to your front and rear. If you don't let the diff unlock and unload power you will never be able to keep consistant times b/c you will never be able to come in and out of a turn consistant enough each time.
IMO a bad choice unless your just dragging or running on nothing but straights. Technical tight tracks would kill you.
RJNicholson is offline
Old 07-15-2009, 11:44 AM
Originally Posted by JAMMINKRAZY
LOL
well im not that smart about this stuff. so why is it bad to lock it and is it bad to lock the front and rear to
Old 07-15-2009, 11:46 AM
ya they would kill me because i cant control it at all. But before i did this the front was getting more power than the rear
because before i did it the front was getting more power than the back
Old 07-15-2009, 11:47 AM
Locked up diffs = no off power steering a very bad thing in 1/8th scale off road.
Diffs have different thickness of oils for the affect you are looking for. I would read up on using different oils with different weights to get the locking affect you are looking for with out fully locking the diff and loosing all your off power steering.
Old 07-15-2009, 11:48 AM
Put a thicker oil in the center. It will keep the diff from unloading to the front or rear so easily.
Old 07-15-2009, 11:50 AM
Jaz240's Avatar
Trader Rating: 52 (100%+)
David, didn't you lock your diff just so you can do donuts? didn't you also disconnect the front CVD so you only have rear wheel drive..You need to let everyone know why you locked your diff or you will just continue to get silly replies. For normal applications locking your center diff is useless, especially if racing..but for what you are using it for you should be fine..Just dont expect the car to handle like it used to..when you get tired of donuts and drifting, take the Putty out of your center diff..you did use some sort of putty like I recommended didn't You? I sure hope you didn't use any type of glue..then you need to buy a new diff
Jaz240 is offline
well all my difs have this screw that i can screw in to lock or screw out to unlock. my LHas said i didnt need any diff oils. I have the ofna lx one
Old 07-15-2009, 11:52 AM
token's Avatar
The puropse of center diff is more of a traction control feature - push/pull - it gives the ride a true 4 wheel drive.
token is offline
Old 07-15-2009, 11:53 AM
well i like to bash around and occasianally go to the track but i will loosen it up so i dont spin out
