Fuel Recomendations
Use whatever nitro percentage that you would be running normally.
I break in and run my motors on Werks 30%
I run Nitro Juice 30% in all my motors. I have used a lot of the others and it is a bit cheaper then alot of the other stuff out on the market. Depending where you live you might not be able to find it yet
byrons 30%
I have had awesome luck with O'Donnell 30%
Best fuel by a mile is Cold Fusion Fuel. Hold a great tune all day no flameouts and engines will idle forever. They even have a special quart just for breakin that has extra lubrication, then you can switch to the Majik 30 % and never have any problems, specially great for new engines because after gallon after gallon it will not dye your internals they will look as good as new after several gallons. Pm me and I can give you the info on the fuel and whom to contact
I can get Nitro Juice for anyone that wants it for $28 a gal plus shipping and handling Or of in the Houston, Tx area can set up a meet or will deliver Just Pm me and let me know what you are looking for and how much you want. Just to let you know when i switched over to it my car ran 12 deg cooler and about 2 1/2 to 3 mins more on run time and never changed a tone from what i was running.
Is Cold Fusion Fuel clear?
So far I've had good luck with Blue Thunder Sport 20%.
