stols when i brake
stols when i brake
hi i have a small problem with my hpi mt2 it just cuts out / stols when i brake when its hot or cold anyone any ideas?
cheers mate i thought it could be a clutch bell bearing, i think the idle is ok but when i start it with the wheels in the air its like its running at 1/4 throttle and when i put it on the ground it cuts out. so on idle the wheels are spinning quite fast??
"stalls"
Replace the whole clutch
Also check the idle - twice in a .21 sirio motor I have the idle screw after some 20-30 min of racing slowly was getting unscrewed. So, when I was with neutral throttle on my buggy, everything was fine, and after the first turn where I pulled the brakes for first time the engine 'stalled'.
A possible cause...
Thank you.
A possible cause...
Thank you.
