kyosho inferno gt2 clutchbell options?
hey guys
now after a rough friday,my igt2 was running pretty good ........ until the engine blew the con rod,high revening for sure on this since i was pushing pretty good,
well i put the 28rr i had back in, and was looking at the clutchbell and was wanting a larger size one.
i only found the 2 speed bells from losi,the ones that fit the lst and as,
my current bell is 15/21 tooth,the losi bells are 18/25t and 19/26t,
anyone know if these will work? i have to replace the high speed gear on my trans anyway since it looks like it shifted hard and made a small break on the spur where the clutch arm engages to shift into second
want to get the most out of it with out having to crank the engine to high,
so any ideas on the bell would be helpful
Guest
Check out the GT proboards, everything you need to know about the Inferno GT, GT2 :
http://infernogt.proboards.com/
