KO PROPO EX-10 Helios q's
#1276
Ray-
#3 is correct. Don't know about the other two. Maybe someone else can help?
-Robert
-Robert
#1277
hey Ray,
#1... not sure for 4cells, as my setup works with the dsm in 4 cells, and other people have problems. i'm lucky i guess..
#2.. nothing needed.... drop in your dsm and go racing....
i'm running KO 2343, novak GTX...
~ming
~ming
#1278
Chances are, a capacitor is all you need to keep the voltage high enough. A light and small 1100uf or 2200uf 6.3v should do, it's the main solution I've read about (and used) when it comes to evening out voltage fluctuations.
Should use it with 4 cells for sure, but it won't hurt for 6-cell too, especially if you use a PT. KO Servos and Spektrum with a PT can be a bit of a load... I know a QC2 would need it, even with 6 cells. I haven't heard so much of a problem with the GTX though.
#1280
Ray..
there are still body post hole.....
~Ming
~Ming
#1281
Ray,
You will love it!
You will love it!
#1282
Hmmm.. hole-less body mounts.. what would that be, magnets? Velcro? Duct Tape? Wind downforce?
One funny part of a TCS Rally race we had was a guy flipped so many times his posts and holes couldn't hold the body on with clips anymore! He had to use battery tape wrapped around the midsection to keep on.. hah.. the jump for that race was insane..
#1283
Would a RF-501F KO Propo FM RF-Module work with a KO 297FZ receiver?
#1284
Originally Posted by ntc3freak
hey guys.i'm getting a ko propo 2343 digital servo for steering this sunday.my question is,can i use the super high speed response feautre(3-channel mode) even though my throttle servo is rtr servo(non-digital.it's the servo that came with ntc3 rtr).just curious.thanks
#1285
#1286
Originally Posted by BrainTeased
despite what i said about the manual not advising to do so, im doing the same thing as you and so far no problems got my fail safe installed though just in case
wow.i'm so scared to try
#1287
Originally Posted by KO PROPO Staff
You can use the Helios with the KR-297FZ as long as you put the radio in the normal response mode. This would be the swithc behind the module (N).
#1288
i am having a very bad problem... idk why but it just started yesterday. when i turn on my car and transmitter the servo is turned to the left about half way. so i set the steering trim to the middle...then after about 30 seconds of driving it just randomly steers to the right. but now it also wont work smoothly either. it has a big delay in the response and it a bit twitchy.
as of now i am pretty sure it is the transmitter b/c i have tried 2 different cars, 2 different servos, 2 different esc's, and i have also poped in a spektrum to see if that help it(and it didnt). i need it to race today or else im screwed
o, and btw, all batteries were fully charged.
thanks,
marshal v.
thanks,
marshal v.
#1289
Originally Posted by Ben.C
So what you're saying is that we can use the Helios with the Mars reciever,we just need to swtich the mode to normal?? Is that it??
#1290
thanks,
marshal v.
thanks,
marshal v.
