KO PROPO EX-10 Helios q's
#106
Originally posted by rc_square24
so if ill be using it in canada, which should i get? 27, 40 or 75?
i managed to get 40 mhz in hk.
#107
Re: Re: 27 or 75mhz?
Originally posted by Headbanger
In the US, there are 6 channel in 27Mhz(1-6) band and 30 channels in 75Mhz (61-90). Outside the US, there are 12 channels in the 27Mhz band. KO sell crystals for all 12 channels in the U.S. for some reason.
Also, 75Mhz is close the frequency of flouresent light bulbs so you might experience glitching in some situations.
#108
Frequency
Hi KO PROPO Staff,
I am going to buy a Helios (most prob 27Mhz) and wondering if it's possible to use a KO 29Mhz frequency on the 27Mhz helios ?
Just like it's possible to use a KO 41Mhz frequency on the 40Mhz helios right ?
Thanks.
Thanks.
#109
The answer is no.
27mhz can only use 27mhz
29mhz can only use 29mhz. (They used to able to use 30mhz Very rare crystal)
40mhz can only use 40mhz and very few 41mhz. It will have glitching problem or interference problem with 41mhz.
KO has all sort of mhz receivers when they have Mars 1 and they trimmed it down to 27, and 40 in Asia. I don't know in US.
#110
Speed8081-
You can not use those frequencies with the 27MHz. Generally, you can get away with something close like 26MHz, but even then you may still have problems. I would stick with the correct frequencies.
In the US 27 and 75 are the only approved frequencies allowed by the FCC. There is a reason why we are not allowed to use the other frequencies here in the US, because someone or something else is using them and could cause problems.
For example, 40MHz is reserved for military and emergency uses. If you are using this and a military jet flies over or an emergency vehicle drives close by, you will get blasted. Also, don't you think that they problably need that channel more than you do?
Just a heads up!
Just a heads up!
#111
Originally posted by KO PROPO Staff
Speed8081-
Just a heads up!
Speed8081-
Just a heads up!
#112
where can i get one online???
#113
Synthesized module and receiver
KO PROPO Staff,
It looks like everyone is releasing synthesized modules and receivers for the their top end radios like the M8 and 3PK. Does KO plan to release their own for the Helios? It would be awesome if they do. I'm sure I'm not the only one waiting for it. Thanks.
#114
Speedtech
MicroRCshop
Speedworld Raceway
and of course
Kopro.com via shopatron
#115
Re: Synthesized module and receiver
Originally posted by forty6
KO PROPO Staff,
KO PROPO Staff,
#116
Synthesized
Just returning from the RCX show and this was the most asked question.
What I have been told, we are looking at about one year before we will come out with a system. We have been looking into doing an entirely different type and style of system (not using POTs to change the frequencies). Most likely, this will be a lower end system and not for the Helios, but I just don't know at this time.
One of the major reasons that I think that it will not be offered in the Helios is because of the size of the receiver. Currently, the KR-302F receiver is the smallest receiver available on the market. Putting the synthesized equiptment into the receiver only increases the size and weight of the receiver. Most drivers want everything as small and as light as can be.
#117
Re: Synthesized
Wish list:
1. Synthesized TX module
2. Synthesized RX
3. Low profile servo
4. KO pit towel
#118
Settings for drag brake on Brushless system?
Hey KO PROPO Staff
I have a Novak brushless system. It's great for it low maintenance, but the only thing missing is the drag brakes. Since I saw that with a Helios, you can program brakes for a Mini-Z MR-01, why not drag brakes for a brushless?
I was going to start playing with the settings, but I figure I might ask here to see if anyone has done it already or maybe point me in the right direction. Anybody know how to setup drag brakes for brushless system?
#119
ko staff i have to say i am happy with the helios its a good system just the way it is going synthysized would be a bad idea
i changed from it back to crystal it just didnt work the same .
#120
Re: Re: Synthesized
You could offset the size of the receiver by coming out with low profile servo like the Futaba 9550. That's another thing on my KO wish list!
Wish list:
2. Synthesized RX
4. KO pit towel
Wish list:
2. Synthesized RX
4. KO pit towel
