KO PROPO EX-10 Helios q's
#856
My friend and I noticied a slight problem this weekend with our Helios radios ( noticied mine first adn the he checked his and it was the same). It seems that when I went to adjust steering balance when I would turn the wheel to the left so I could adjust it I could not get the "*" that should show up next to the "left" adjustment showing it can be adjusted. It appears that the drop/tilt wheel attachment may not be exactly molded right for it to allow the proper travel. A slight amount of plastic had to be removed from the wheel stop. Has anyone else had this problem. I also suppose it could have been the wheel molded wrong but either way that is a problem in manufacturing that needs to be looked into.
#857
you jut need to go into the vr adjustments and re-calibrate. I beleive that the recommendation is to do that every few months or so
#858
Yeah I saw that but also saw it recommended it could mess the radio up and would have to send it in for service. I will look at it though. Thanks theisgroup!
#859
np jay. had to do that to mine when I first installed the drop wheel.
#860
10-4, hopefully all will go well.
#861
ya, you really should re-callibrate the VR on the throttle and steering every month. and no, it wont mess up the computer.
#862
what is vr???i really dont understand.can anyone tell me how to use it???
#863
Search a couple pages back...
#864
#865
Originally posted by promatchrcr
Will do, thanks guys.
it'll say No/Yes. select YES - hit Enter
the first set of VR is for steering. turn the wheel to the left (you'll see the setting change) then hit enter. turn it right and hit enter. netural.. hit enter
next is throttle
pull on the trigger. then hit enter. hit the brakes.. then enter. then at neutral hit enter.
it will flash COMPLETE. and your set.
#866
Cool, I will do that this evening when I get home.
#867
NTC3Freak
Here is a picture of the Helios with the angled extension.
#868
NTC3Freak
Here's another one: Notice the wheel?? It's a little "look fast" technique that scotty taught me!!
Hebiki: cool!! Did'nt lknow about the calibiration thingy!!
#869
VR - I think it stands for variable resistor. I think what you are doing when you are resetting the vr setting is adjusting the pots of the variable resistor.
#870
You guys ready for the Spektrum....
Horizon is shipping mine on Friday....but then again I backordered mine three months ago and since I live in So.Cal. the LHS won't get there shippment until late next week.....I will let you guys know how it fairs....I CAN HARDLY WAIT>>>>>>>
-Stephen <><
-Stephen <><
