KO PROPO EX-10 Helios q's
#46
Question
It's my first time to have a module type of controler.
So, If I have a 27Mhz module, I can change it to 40 Mhz, so I could use some of my Phaser Rx? Will it also work withthe NOVAK module so there will be no more Cystals?
Thanks! -Lem
Thanks! -Lem
#47
Originally posted by KO PROPO Staff
loosenut,
The 75MHz module and receivers are available. With these installed you can use 75MHz.
loosenut,
G
#48
Originally posted by loosenut
Thx for where can I buy just the module? I can't find them anywhere...
G
G
You can order it from your LHS or purchase it online through shopatron.
#49
Has anyone found a hard case that the helios will fit in with the drop wheel?
#50
so i take it the xxx-l rx will work with my mars "r" ??? or which other rx can i use im on 27mhz.. thanks
#51
I just got my helios and i have to say its an awesome radio alot better than my m8 .
#52
someone asked this before but it never got answered:
will the 302 receiver work with the Mars R? thanx.
#54
loosenut,
loosenut,
When I type in module in search...it the mini z module shows up...
Gary
#55
loosenut,
The moudle for 75MHz is item number 81246. Look this up in the search.
#57
Compatible servo's
Maybe this question has been asked but here it goes again, Can you use any standard non digital servo (Futaba S3003) with the standard KO receiver (302) that comes with the KO Helios?
#58
looking at the response mode table, does the AHRS only work with those ESCs?
ive got a duratrax DTXM1080
http://www.duratrax.com/caraccys/dtxm1080.html
and dont plan on upgrading till brushless.
#59
Re: Compatible servo's
#60
Help!!!
Call it stupid, but I accidentally placed a small amount of
(Prol-Line) Liquid CA to keep my antena from fallin off, but a small amount went inside the tube and got to the antenna wire.
What is the best debonder for this type of CA?
KO PROPPO STAFF:
and if while doing so the antenna wire gets cut, can I replace it or just add wire to make it the exact lenght again?
I'm using a KO302 Rx.
Many Thanks!!
Lem
KO PROPPO STAFF:
Many Thanks!!
Lem
