KO PROPO EX-10 Helios q's
#391
Originally posted by TimXLB the RX crystal still come with the plastic cap but not the TX to bad .
Tim:
Hi,
If you need a radio for Cleveland just let me know. Mini has two right now one with a drop down and one without (drop down is on it's way) one is 27 and one is 75. along with a M8 and a 3PK. LMK
Keith Billanti:
Hi,
I always wondered the same thing... I did find some 75 band crystals with the plastic covers on tho.
Tim:
Hi,
Keith Billanti:
Hi,
#393
Hello B4,
I have been told they will work without any problems....
The Helios Rock's by the way, I love it!!!
#394
HEy Guys,
I tried my helios for the first time yesterday, after a couple of packs with my R1. The menus are very intuitive, and their customization is a great feature. However, I was disappointed with the supposedly quicker response speed... frankly I didn't feel any difference from my R-1... I run the HRS receiver with a 2113 fet servo (analog). In the manual they say to make full use of the HRS mode you need a recent KO digital servo... On the paper the new Sanwa ERG servos have better specs than the KO's. Would they (other brand's digital FET servos) be appropriate for the HRS mode, or do you really really really need a KO servo to feel it?
Thanks,
Paul
Thanks,
Paul
#395
Originally posted by Lonestar
HEy Guys,
Thanks,
Paul
HEy Guys,
Thanks,
Paul
You need to use the Ko digi servo's.
If you use the PDS 2123 servo (#30021), you have a quicker servo as the Sanwa. I asume you wanted a electric-car servo?
If not check kopropo.com, I'm sure you can find a high-speed servo there for your needs.
Thomas.
#396
Originally posted by 840918001
Hi Paul,
Thomas.
Hi Paul,
Thomas.
Thanks for the heads-up,
Later,
Paul
#397
3rd channel quick steering
I'm not sure of the term this is but...
how to configure the helios so i activate the 3rd channel the car overrides the dual rate, and i get full lock to lock?
The JR R1 and the XS3 can do this, I am just wondering if this function if proprietary to JR, or can the Helios do it as well?
#398
Hi,
Just got my KO Helios with the adaptor and am happy with the way it feels on my hand. I still have to thoroughly try this out this Sat. during our club race. The only thing I don't like about this is the Manual as you would need to do a bit of deciphering to understand the English.
Just like to verify about the steering setup, what would be equal to EPA and DR? Is it advised to setup EPA to 100% L/R and adjust the DR to get the steering?
Thanks.
Thanks.
#399
Originally posted by rcspeedo
Hi,
Thanks.
Hi,
Thanks.
Hope this helps,
Mike Patterson
#400
Thanks Mike for the respond. I know about the D/R and the EPA. I probably was not clear on my question. I was looking for the Helios option equivalent to the D/R and EPA, is it the Steer Travel and Steer Balance only? I also noticed that ET4 is an additional adjustment for the throw.
#401
I have a problem with my radio system.
Today, I soldered on a new motor and everything, hooked it up, turned it on, and then the servo started to "pulse" and making buzzing sounds. I thought it was just the servo, so I swapped in another servo and it did the same as well (one digital, one analog). Then, I thought it must've been the receiver. I swapped out the 302F and put in a new 302F in with the same crystal. Same problem.
I also had low batteries on the transmitter (~10.4-10.1 beep).
Could this have caused it? I heard low or bad transmitter batteries are sometimes the problem with glitching.
Any help will be appreciated.
#402
#403
Using analog servos in Advanced HSR will glitch the servos and probably damage them.
#404
Glitching
I was wondering if you guys had any tips on eliminating glitching .last weekend at the regionals at hesparia my car glitched so bad i shouldnt have even tried to run it..but it is a mars not a helios..i tried everything and it still did it..
#405
Re: Glitching
when i had the Mars R... i did glitch once.. but when i checked... my crystals were bent. check to see too if your antenna wire isnt damaged or touching the chassis.
