Please help with battery charger!
I have a orion 1600 battery for my reciever. I just got a superbrain and i am charging at 1 amp well, it's a 6 volt battery and it is reading 6.6 volts now?? isn't that past fully charged? and it's still charging getting close to 7 volts?? WTF?
That's normal
A "6v" pack can be as high as around 7.2v when fresh off the charger. It's normal. When you use the battery, it will fall to ~6v quickly and stay there for a while.
assuming my battery is dead. How long would a 1600 nimh at 1 amp on a superbrain charger take to charge? 1 hour? half? just wanna know how long i will be sitting here.
BTW i had a 8 hour wall charger before i got the superbrain
thanx jazz. It must be dead as hell cuz it's taking forever. Maybe i just want to race really bad
Not to be argumentative against Jaz, but...
There is no *need to cycle nimh batteries. They don't suffer from the memory effect associated with nicd. If you do cycle them, don't go below 1v/cell for nimh (or 0.9v/cell for nicd). That means your 5-cell Rx pack shouldn't be discharged below 5v during cycling.
*A new nmih battery won't function its best until it's been used and charged five times or so. Some people speed up this process by cycling them when new.
Nimh do suffer performance depending on how you take care of them. If you never run them down below 50% charge they will do something like the nicads did & if you let them sit too long they will have problems charging. But you are mostly right mark they are much better than nicads just not as good as they were hyped to be. No battery tech thats marketed to us is as good as promised when released.
