Best Pipe for Novarossi P5
i am interested in the efra 9901 would this be a good match
or any others you can recommened
Thanks ben
Thanks ben
I am using the ofna 086 and a rb 086 (two cars one motor). Hands down best pipe for the p5. I have tried a 053, jp1,2,4 ( I will never use a jp on a rossi again) as well. 086 smokes them all.
ok i am interested in the 086 however hard to come by in the uk
have any of you guys running the 086 compared it to the nova 9901
also can someone give me a quick explanation on glow plugs i run 25% byrons
here in the uk atm the temp is around 25C (77F) if the weather is hotter do you run a colder plug or a hotter one also what plug is best for my p5 C5s or C6S
Thanks in advance
Thanks in advance
also what temp does this engine like
I have run 86, 53, and 1005 pipe on mine in the past - currently running Dyn 86. The 1005 gives the most peak hp, but I it does not tune as well for me and has less fuel mileage then my 86. I prefer the 86 with the medium dyn header for broad, smooth powerband with decent mileage (read not great..I cannot go 7.5 minutes with mine, but it is getting a little worn out too)
