Kyosho ST-RR Dogbone Problem - HELP!!
Ok all you ST-RR pilots...I really need your input!! I'm having a problem with my front dogbones popping out of the outdrives when landing off big jumps. Before you go there, YES they are the ST-RR long bones and not the ST-R shorter ones. When you compress the arms all the way upwards, you can see that the pins are close to the outer-most end of the outdrives. This does not occur at the lowest arm position, as I've already tried to solve this by adjusting the droop. I've put a small spacer on the outside of the shock shafts to limit the travel, but perhaps it not a big enough spacer? Any advice here would be very welcomed, and THANKS!! I'm frustrated as you can tell
Tech Prophet
i am curious as i have seen this problem posted a few times
Monty, nice talking to you. Don't forget to post those compressed measurements we discussed, thanks!
Anyone else care to contribute a solution?
Thanks Monty, good luck finding them. Ehames005, thanks for looking at your RR. I just recently rebuilt the front diff completely with new outdrives (diff cups) so I know they are not worn at all. This may just be a fluke deal where I'm just lucky enough to be landing the jump off-kilter enough on 1 front wheel such that it goes MAX compression at just the right (wrong) point and allows the bone to disengage. It's happened once before in just about the same manner, which is what has me worrying about the condition. I'm also afraid to restrict the shock dampening too severly such that it effects the pre-load or pack entering the jumps. YIKES!!!
I'm pretty sure I do, they are what come stock in the ST-RR kit. The ST-R upper arms where shorter I believe. There is barely enough of the adjusting screw visable between the upper arm and end when connected to the middle or inner hole on the hub carrier to adjust the front camber angle, so it must be the long upper arm.
Interesting thought Red! Actually I've recently replaced one of the front arms due to some breakage, and come to think about it the other older arm is where I'm having the trouble. I have a few new ones laying around so I'll replace it just for grins anyway. So Red, what makes them sag over time...Kyosho's plastic is pretty decent I thought?
Tech Prophet
here is the positions
Monty, are those your normal shock positions? You're running 1 hole down on the tower and 1 hole in on the arm compared to mine (basically the same laydown angle). My droop is also set at 116mm, so I need to check total compression distance. That positioning would result in LESS overall range of travel for your arms, which might also be a good thing. Thanks!
Monty, what weight shock oils are you using front and rear? In the above picture #043, what the heck is that thick silver thingy between the blue hub and the carrier? I don't have anything like that on mine!
