Team Magic G4RS 2009
#1381
We tested this a couple of seasons back while running the evolva shocks the shock case is longer holding more shock fluid giving it a better damping the improvement was mostly on weight transfer it helped a lot making the car more stable in the rear giving it better on power cornering
im about to rebuild my shocks now so ill wait toll i get the kyosho evolva shock's and see for my self
o ya anyone have a new set or mint set of kyosho evolva shock's there willing to sell me hook it up
#1382
Trader Rating: 26 (100%+)
looks like im buy a set of shocks for my car now lol man when will the spending stop
#1383
#1384
#1385
Ok
Here goes as i stated in some of my posts this is what i had already,so i figured i would give them a try,im not telling anyone to buy anything.Put it this way when i ran the kit shocks an springs let say at our Fort Myers track laptimes average 14.1 14.0.When i tested the {evolva, xray spring combo} not changing anything but shocks, an different spring combos,lets say xray pinks rear,serpents reds up front laptimes 13.8 13.6.Why i did this is because i have chance to play around with different spring rates.An agian if your the only TM car at an event wouldnt it be nice to have options, same goes for my clutch setup also our next state race is coming up soon, i will testing the 24t pinion from x-ray so, my gearing will be 17/62-24/56 MurnanM RBM3.An if i can use anything to make my car faster, isnt that how it works, an Randy has see my car run.Also my car is setup to run basicly any clutch i want as long as the gear mesh matches, i can run these following cluches Sirio power clutch,X-ray,Capricorn or Kyosho at a big race you can find these options.Love Tm G4rs 09 as stated before, if it makes me faster i will use it, just my 2cents.
#1386
The standard shocks can be improved upon for sure.
I think what we are saying here is dont stay home just because the standard shocks are all you have... they do a decent job.
#1387
im not going to let my car sit till i get new shock's im still going to keep them and run them im happy with them
im just getting more input on what everyone is doing to there car pro's and con's so i can test it my self and make the car better
the only real thing i dont like about the car is how much flex it has in the rear lower arm's there is got to be a way to fix that
#1388
I assume you mean there is excessive play in the rear arms at the pivot mounts ... It does get a little sloppy... I think the KFactory mounts help a little.
#1390
Guys today raced a G4RS09 fr the first time.
Great experience until a-main, i was on 2nd place of a 30 minutes a-main, when my 2 speed gearbox started to fail, ended last 15 minutes on 1st gear ... the 2 speed box seems to be fine "by eye" but it doesnt make the switch to 2nd , any tip ?, ended on 5th place ...
thanks,
thanks,
#1391
g4rs 2speed
the 2speed works by centrifugal force and shifts by engine rpm. try adjusting the screws on the 2 speed shoes out 1/4 @ a time, untill it shifts where you want it to. there can be other reasons its not shifting. like gearing. so let us know if that worked or not.
#1392
Could be a oneway bearing problem?
#1393
Trader Rating: 13 (100%+)
It could also be that the inside the two speed housing gets a little oily (a common problem with some cars) from fuel or freshly oiled bearings. Scrape the surface of the 2 speed clutch shoes clean with a knife, and clean the inside of the housing with Methylated spirits, and see if helps.
We have to do this a lot in our Kyosho, and a mate of mine has the same problem every time he services and oils his two speed housing bearings in an XRay NT1.
Kindest regards,
Lars.
Kindest regards,
Lars.
#1394
thanks,
thanks,
k14239
k14240
