Team Magic G4RS 2009
#1291
Awesome.. are you driving, flying.. where are you staying? There's room at my place if you want to save a few coins!!
TrackSideRC opens at around 9am and hence the track is open 7 days a week for practice. There's no 12v outside of events and for 240V you should look to the tyre truing area where there's a power point, it can be arranged to be on.
Your default Moorebank setup should come close to the mark, perhaps a suspension softer as we are slightly bumpier than silky smooth Moorebank but it's not too bad. You'll be entering MUGEN territory... So beware!!
Looking forward to meeting up in the garages!!! There might be a chance a practice session goes into the evenings under lights too! Depends on how many at the track. We are currently exploring a new timing system and results will be posted regardless.
h
Attachment 621833
h
Attachment 621833
Thanks for the offer for the spare room as my father relation has a three bedroom house. one for me, one for dad and one for the car.
And yes we will be driving up, as now i have my license we can share.
Thanks mate for replying, good to here from you. Hope to see you and guy up there hoping guy is in my heat again.
#1292
Trader Rating: 26 (100%+)
Dario is 11th after 5th round at the worlds
#1293
#1295
Hi Guys
I ran the car on the weekend and i was very impressed. i improved my laptimes by .3 a second from previous weeks qualifying sessions then was able to get within .2 of the fastest lap in the final.
I wasnt able to push the car as hard as i had an off power oversteer issue which after a few changes is getting better.
i have a few things to try next club day:
-short rear camber link as im running close to 5 degrees rear camber trying to keep the tires wearing flat
-going from 60k rear diff to 80k really settled the car down so i will try the 100k (xray oils)
- wider front track width as im running 197.5 . i will widen it to 199
- a bit more caster
The car has plenty of front grip so i just have to find the sweet balance spot. i will post my setup when i get a chance
- a bit more caster
#1296
Unfortunately, almost nothing is compatible between RS and RS2009 or so called RSII, which actually should've been called G5 to avoid confusion.
Part numbers for RS:
K1493 front belt
K1494 side belt
K1495 rear belt
Part numbers for RS2009:
504069 front
504116 side
504072 rear
Saludos
AFM
#1297
Not sure if anybody else has had this issue but I have had issues with the Diff in the Rear of my G4RS 09.
The issue I found was due to the Belt Tensioners being around the wrong way... now what I mean by that is that each Orange belt tensioner has a very mild notched mark in it at the top side which is marked inside the "serated circle"... initially I set these at the top of the Diff which then rubbed on the actually chasis plate... when I reversed it so that they are now both at the bottom the Diff freed up and now spins beautifully.
I have highlighted them as they appear in the manual below. These must sit at the bottom of the Diff Bulkhead 504057.
Hope this helps folks with assembly.
#1298
Glad to see you back
Hi Guys
- a bit more caster
- a bit more caster
#1303
G4RS 2009
Hi all,
I am involved with the new distributors of Team magic in south africa, i'm promoting the product by racing the car for them in our national and regional series.
I love the car, easy to drive and the box setup gives plenty steering, I can put the car where I want it.
The advice I need is on the biggest problem I have. I think vibrations are causing interference with the reciever, at full throttle the sterring goes crazy and the throttle stays wide open, this only happens when the engine is started, what could be the problem? and how can I solve it?
Rowan
Rowan
#1305
Well I know its no loose connections on cuts in the plug wires because I ran the same electronic setup in my Mugen yesterday without any issues what so ever
