Team Magic G4RS 2009
#226
So how is your car Impalabob64? have you tried it yet? what you like or dislike about it. now that I have shown my bothers what this baby can do, they will both get one
#227
HI
I have run the car today and it was awesome, it was going like it was on the train track. Even with the stock set up!!! I think TM is so close to the best car ever!!!
But, i still have my clutch problem First i forgot to cut the clutch shoes, it was my mistake. But even after cutting them, the clutch wasnt engaging. Then i installed the K factory teflon centrifugal shoes and it was working like a clock. No problems at all. Then i reinstall the original shoes, didnt engage at all. I do intall them as it is shown on the manual but still doesnt work. Dont know what to do !!!
BUt the car is awesome !!!!
#228
mettuchi contact tm and i am sure that they will be willing to help you and fellow tm racers with this problem
#229
HI
#231
HI
anyway check that those are not binding with the flywheel pins.
#232
#233
actually any difference if the weight sits between 2 pins or the pin going through the hole?
isn't the weight will be 'thown-out' more evenly and consistant if it sits between the 2 pins? anyway i'm not sure...
#234
oh, TM changed to the 'style' that XRAY is using in their XCA clutch where the flywheel pins will go through a hole in the weights.
#235
its not like the UFO , the throw out needs to pivot on the pin to try to come out of the flywheel, causing the clutch to engage. the UFO throw outs were sliding outwards. So it needs to be in either end of the throw out shoe. there will be more tuning to make them throw out the other way. same way as rotation.
#236
unfortunately i havent kept up to date with the TM since the G4RS. seems so many cars since
#237
Better now?
HI
I would think worn in shoes develop a slight curvature and can see Teflon ones in my inbox pretty soon. Pics..First time Ive seen the clutch in detail ...
#238
This is the same type of clutch Serpent calls Centax III and uses from 710 time till now.
#239
I've just started to build the RS and found there are some gap from the middle shaft. Should i actually shim it to make it fit
herewith the pic
Secondly, appreciate if someone could provide the diamension for the linkage bending.
herewith the pic
#240
I did 40 degree bents first 40mm from the tip of where you screw your ball end I will post a pic if you need to see it. Let me know.
