Team Magic G4RS 2009
#1562
Victory is mine!
Spent about an hour or so today with my mates at the Local Hobby Shop today and finally got everything mounted to my satisfaction
The battery is tucked away nicely in its spot and everything is working a treat!
Just have to have the right weather to go down and give it a spin
MuchMore CTX MRG-5A 6V Regulator and LRP79911 1700MAH Li-PO
#1563
My G4RS
I considered that idea but after checking prices for them in Australia ($200 each for decent ones) it just seemed to expensive. I am lucky though as the KR-407S Receiver I have appears to be rated for 7.4V already which is some good news
Thanks for the tip though Getpip and I'll keep my eyes out for them at a cheaper and more wallet-friendly price I should hopefully have all this rigged by next weekend... maybe sooner depending on orders at that though my local hobby retailers.
Thanks mate! Your welcome! Any chance of seeing that G4RS of yours under the hood? I love seeing them in all their glory! What are the symptoms with your pack... mine had issues charging and for the life of me would only get to 850 MAH which is ok... but at least 300 odd off what it should be... my local retailers ensure me that this is ok however but I am not sure why it isn't charging fully considering its only relatively new (about 6 months old).
Finally I managed to find a web retailer for my Li-PO Pack that I acquired recently. For those interested in Li-PO'ing your G4RS in Australia you can get them from www.frontlinehobbies.com.au for around $60 shipped (Express Post). The model is the LRP 79911 - LiPo RX PACK AAA HUMP 1700 RX 7.4v at 53x30.5x20.5mm Hope this helps those keen on a larger pack... just don't forget the 6V Regulator for it as well.
Here are some pics of what is under the hood
Next week there will be put in an other engine...a Picco Evo4 Ceramic Modified by our Picco Dist., where have been made improvements on Low, Mid to Top End!
#1564
I found out that the pack does not reach its maximum capacity..so I should change the battery or better put in a Lipo too
I took my G4 out for a swing this afternoon... only did one tank as the day was getting on and wanted to spend some time with the wife due to us celebrating Valentines Day early due to us both working tomorrow.
The G4 did perfectly... I am really satisfied with it and can't wait to update the Servo's with the new Low Profile ones that I am picking up mid week... that should give me a lot more room underneath the hood to mount the Li-PO and the Regulator properly. I contemplated the High Voltage Servos but couldn't find any that I like.. not to mention I have the K Factory HiTEC Servo Horns so it kind of makes sense to go with HiTECS.
http://www.hitecrcd.com/products/dig...hs-7775mg.html
#1565
Victory is mine!
here a pic with a full size servo mounted
if you would like to know more about the pack pm me
#1566
Nice idea but I think I will stick with the Li-PO Pack that I have for the time being as I could not really find any quality Li-FE Packs that would fit. I did have a fair look around for them but trying to get this sorta stuff in Australia can be difficult.
From what I can see you have about as much space as I do really. My Regulator will be moved tonight and will then fit in behind the throttle Servo which is going to be replaced by the Low Profile one so everything should be a little bit more tidy.
Apart from that all should be good for weekend
#1567
G4RS 09
Now it's built in, the Picco Evo4 Tuned Version.. can't wait to run it
#1569
Which kind of upgrade would you recommend?
#1571
I would say this is the most important to fix what is a weak point on the car.
K14200
http://store.cometrc.com/product/105...er-k14200.html
see it fitted here:
http://www.cometrc.com/index.php?option=com_content&view=article&id=79:g4 rs-k-factory-upgrade-parts&catid=37hils-arena&Itemid=55
These are also useful:
http://store.cometrc.com/product/110...er-k14224.html
http://store.cometrc.com/product/110...er-k14223.html
K14200
see it fitted here:
#1572
K14200
see it fitted here:
K14200
see it fitted here:
the k14200 and the k14201 should be the first thing you buy even before building the car
#1573
K14200
see it fitted here:
K14200
see it fitted here:
TRUE TRUE TRUE!!!! they are MUST have parts,
I have briken 3 standard rear shock stay, with NO big crashes!!! until I put the Kfactory!!!
The yellow Clutch shoe and the teflone flys are also GOOD, look at them.
Have fun a keep tuning.
BTW,VERY happy with the G4RS09!!
#1574
Sorted my G4RS 09 Out!
Have the new Low Profile Servo Installed and the LiPO Regulator mounted to the back of it via a small amount of Hot Glue I have managed to replicate the general look of the standard pack as well as the connections... although these have been updated to JST Connections as these look and feel a little bit more secure.
Everything is working well and the Car just needs to have the fine points adjusted which will be done on Thursday Hope you all like!
#1575
hello
what is the most common body for 200mm
