Corally RDX Phi 09 >
Corally RDX Phi 09
Corally RDX Phi 09
Old 06-21-2011, 02:22 PM
  #691
seaball's Avatar
brad johnson.
seaball is offline
Old 06-21-2011, 05:08 PM
  #692
mattwoodcraft's Avatar
Originally Posted by BJohnson
Corally USA / Specialized RC offers steel bones with steel blades.
thanks in open are people usimg steel all round or just putting in the front
mattwoodcraft is offline
Old 06-22-2011, 04:55 PM
  #693
Randy - Just put a 42 tooth spool up front and run the BD5 Gear Diff in the rear. You will end up using the same belts as I had posted earlier.
i to will be getting the BD5 rear gear diff how are you finding it with the difference in ratio ?
all the bearings are the same ?
Old 06-22-2011, 06:25 PM
  #694
BJohnson's Avatar
Matt - I am using the Corally bearing holders front and rear. I have installed two bearings on each side. This way I am able to shim the inner bearing closer to the gear diff to remove slop and adjust the gear diff from side to side. I had to remove a small portion of the shock tower to allow the gear diff to rotate freely. I also had to open the chassis a slight bit for the same reason. Make sure you watch for clearances of the gear diff. Hope this helps.
Most people use the steel blade in the front only.
BJohnson is offline
Old 06-22-2011, 06:35 PM
  #695
MAD916's Avatar
I had started using the Delrin front spool and metal blades on aluminum +2mm dogbones. just could not keep the plastic CVD blades alive runing either the Alum or delrin front spool, but with some help from Rob we now push out the pin on the +2mm dogbones and replace with the metal blades been orking awesome......
MAD916 is offline
Old 06-24-2011, 03:24 AM
  #696
where do they measure the dog bonesa are the corally bones 44mm ?
Old 07-05-2011, 09:26 AM
  #697
Been working on getting the Tamiya TA05 gear diff to fit right in the corally with same sized pulleys front and rear , will post pictures up when finished hopefully before the weekend.
weekendracer_uk is offline
Old 07-07-2011, 02:23 AM
  #698
Default rdx phi straight arm and narrow chassis set up help
hi all, i'm looking for a base set up and build tips for the rdx phi with the new chassis and arms for running outside on tarmac, as the instructions show the model with the old type of arms.
This car is the newest type on the market in the uk which are being sold by modeltech racing.
regards matt
matt prigmore is offline
Old 07-07-2011, 02:34 AM
  #699
Got your pm , will sort a setup out for you shortly. Just off to see Mike so will and pinch his as Mark is doing better with his car than i am right now.
Old 07-07-2011, 07:30 AM
  #700
thanks weekendracer.
Old 07-09-2011, 11:22 AM
  #701
Well thanks to Mike Smith at Modeltech ( UK corally impoter ) for doing the finishing touches the gear diff install on my car is finished.
Used:
Spec-r Tamiya TA05 gear diff 37t
Tamiya one way pulley 37t
Corally 510mm front belt
Corally 186mm rear belt
std 21t layshaft pulleys
Corally alloy rear diff bearing holders
You need to shave some material off the bearing holders and the high spots on the gear diff case, dont over do it i.e. little at a time and recheck fit. Front one way pulley needs center hole making slightly bigger and drilling new screw mounting holes.
Video is first test run with gear diff after not driving the car for the last five weeks so a little rusty. I run 17.5 non boosted at my local club.
+ YouTube Video
Attached Thumbnails Corally RDX Phi 09-corally-2011-004.jpg   Corally RDX Phi 09-corally-2011-005.jpg   Corally RDX Phi 09-corally-2011-006.jpg   Corally RDX Phi 09-corally-2011-007.jpg
Old 07-10-2011, 03:09 AM
  #702
Holmenkollen's Avatar
Another solution.
Holmenkollen is offline
Old 07-10-2011, 12:27 PM
  #703
Im guessing thats a tamiya gear diff for the 417 , no idea about the spur gear mount though.
Why the huge hole in the spur gear ?
Old 07-11-2011, 02:10 AM
  #704
Uziman's Avatar
Used:
+ YouTube Video
Nice Info, Thanks for that...
Uziman is offline
Old 07-11-2011, 07:30 AM
  #705
it was all from Tamiya i think , the hole is for the inner screw on the motor saves removing the top deck to move the motor
sidecarphil1 is offline
