Corally RDX Phi 09
#196
Try the set-up out the manual. Just change the camber as needed, set front toe to about 0.5 deg. out. This would be a good starting point. All I have changed in m set-up is to put spacers under A-arms to get a good roll-center. I also reduced rear toe-in.
Great car, good luck...
Ciao
Ciao
Hi all,
The car is really good, I have only one question:
When I turn (left or right) the car a little more “intense” the front tire/wheel touch the “ball end” in the shock.
Reducing the steering in the radio I can’t do good angles.
I’m using the front out hole like in the manual.
by the way, how about setups for this car? I found a lot but not for Corally 2009.
Regards.
Robert - Brasil
Regards.
Robert - Brasil
#197
Hi all,
Regards.
Robert - Brasil
Regards.
Robert - Brasil
I experienced the same issue with the wheel rubbing on the lower shock eyelet. I simply had too much lock and reduced the end point until it no longer rubbed, still have the same amount of steering on the track.
#198
Ciao
Ciao
I have heard of a few people changing the anti squat by only putting them under 2 blocks instead of the 4 rear blocks.
#199
Hi all,
Regards.
Robert - Brasil
Regards.
Robert - Brasil
Check with S. Nicholson on the Australian Phi 2 thread for his outdoor setup. Simon has had the car for several months and is a pro at setups.
Cheers!
Bill
#200
I have posted this question in another PHI tread,but i post it here also.
I think i will move the shock at the rear of the shock tower on my PHI09.
But it seem's i must use tamiya wishbone too do that well?
Which type of tamiya wishbone do you use? Short or long type?
And if i use Tamiya arm's,can i still use PHI09 driveshaft's?
#201
#202
Improvement point
Hi all,
An important improvement point is the pivot ball (m3x2.5 mm) attached in the steering lever.
For modified, the one (pivot ball ) that came with the kit is realy short.
Attached a video, Campeonato Paulista (São Paulo) first round in Brasil last weekend, I was in the second place, when…..tan tan tan…..”I flied in the tree”.
By the way, happens with more one friend in the same round.
http://www.youtube.com/watch?v=H0gKY..._embedded#t=34
Best Regards
RB
Best Regards
RB
#204
Hi all,
#205
pivot ball
#206
Do you have the alu steering lever? or did this happen withe original plastic one?
#207
steering lever
This “small issue” only happens in high speed, that's “THE PROBLEM”
Regards
RB
#208
Hey Guys, having trouble fittng a body (Proline R9R) to my 09, can't seems to get it low enough, do you use the bottom body post screws or something else ?
#209
I have converted mine to the 07-08 PHI rear body post plate and posts, I did it though due to lazyness I didnt want to redo all my bodies with new holes.
#210
Depending on which rear uprights you use you will have to fit them to get the proper clearance to make them work properly.The other factor is the Tamiya outer pins are 2.6mm and the PHI are 2.5.
