Serpent 733 1/10 200mm touring >
Old 06-08-2009, 06:49 AM
choisan's Avatar
Default Serpent 733 1/10 200mm touring
Seen from Serpent's web, let's start the discussion here.
As copied from the web's,
733: Main features
- New geometry and roll-centers, lower center of gravity and modified weight-positioning for improved grip and better balance.
- Adjustable caster, camber, toe-in, width, wheelbase front and rear, ride-height, roll centers and more.
- alu front lower bearing blocks and suspension brackets, with integrated anti-roll bar holders and integrated alu middle bearing block
- ball-raced wire type front anti-roll bar system, more efficient and easier to tweak
- new servo-saver design, mounted on the chassis only, with new and easy to mount linkages, options to change ackermann
- split type rear end assembly, with alu holders for 2-speed/brake (from 966) and integrated anti-roll bar holders, and also split type rear alu bearing blocks combined with alu suspension brackets for easy differential access.
- New, very accessible brake system, with large ventilated disks, lower in the car, with ready to use race brake-pads
- New nylon suspension parts / wishbones front and rear
- New rear uprights and keeping the latest 720 steeringblocks, both combined with the lightweight alu pivotballs and nylon ball-cups.
- Very thick and strong carbon shock-towers front and rear with a variety of positions.
- High quality steel parts, stainless steel high speed bearings, allen type steel screws throughout the car
- Race proven Centax clutch (a Serpent innovation) combined with the reliable LC 2-speed gearbox
- New gear-ratio combined with new pullies with small sideholes to let dirt out and new drive-belts.
- RCCX shocks-sets with 2009 modification on rod-support and x-ring.
- New light-weight gear-differential, mounted lower in the car, same diff front and rear, just pulley is different. Combined with light-weight drive-cups, cvd’s in the front and driveshafts in the rear
- 3mm chassis plate 7075 T6 with closed type design, combined with U-shaped motormount which can remain on the engine. This mount, then goes on top of the new alu chassis stiffner. Perfectly positioned. This stiffner has arms to the front and back to influence flex, depending with how many chassis-screws its fastened.
- new low 75cc fueltank with AFL-cap more to the front and mounting-position for AMB transponder on the bottom
- carbon fibre radioplate assembly unit contains fuel-tank, belt-tensioner, both servo’s, receiverbox, battery/holder (accepts normal and Lipo-pack), transponder-holder all as one easy to take out sub-assembly. Ideal for easy cleaning and access. All wiring very short and compact to mount. Nice straight servo-linking to brake and throttle levers.
- New asymetric roll bar with integrated sleeve for the fuel-cap strap, roll bar doubles also as end-stop for the fuel-cap.
- Full color manual/ref-guide and nice logo-decals and a new design small exclusive packing box.
choisan is offline
Old 06-08-2009, 07:32 AM
spurgear's Avatar
Fantastic!
I see it on their site
spurgear is offline
Old 06-08-2009, 07:36 AM
spurgear's Avatar
whos pre ordering!
spurgear is offline
Old 06-08-2009, 07:47 AM
choisan's Avatar
our local resellers said it is on sale next month-july
but still to see.....
choisan is offline
Old 06-08-2009, 08:00 AM
Serpent-Dan's Avatar
Trader Rating: 18 (100%+)
I still don't think it will be out next month if they raced the car this weekend and didn't have enough parts in case of crashes. They are still fine tuning I think august to september release.Can't wait to get mine.
Serpent-Dan is offline
Old 06-08-2009, 08:30 AM
beta bob's Avatar
Trader Rating: 2 (75%+)
How much do you think its going to cost? about the same as the 720 '09?
beta bob is offline
Old 06-08-2009, 08:32 AM
flylow's Avatar
Thumbs up serpent733
good luck
flylow is offline
Old 06-08-2009, 08:38 AM
beta bob's Avatar
I just realized that the rear end doesn't have that carbon "s" chassis stiffener
beta bob is offline
Old 06-08-2009, 08:43 AM
Should be more than a 09 kit. 450-520 range
Old 06-08-2009, 09:41 AM
That looks totally new... amazing!
_cyclops_ is offline
Old 06-08-2009, 12:04 PM
solitude127's Avatar
Trader Rating: 21 (100%+)
The engine looks really moved forward.
solitude127 is offline
Old 06-08-2009, 12:16 PM
Nitro-Racer*'s Avatar
i think that it looks more forward because the rear is very nude?
Nitro-Racer* is offline
Old 06-08-2009, 12:31 PM
Geberit's Avatar
What's the deal with the front bumper? More down force on the front axis or more cooling for the engine? I guess both!
Geberit is offline
Old 06-08-2009, 01:35 PM
spurgear's Avatar
Im thinking those springs are there for illustration. It looks like the older ones and its mixed up. Shorter is supposed to be in front and longer in the rear
spurgear is offline
Old 06-08-2009, 02:24 PM
RC MARKET's Avatar
Trader Rating: 12 (100%+)
i'm think near NT-1 price !
RC MARKET is offline
