Serpent 733 1/10 200mm touring
#3437
#3448
Never use loctite plastic to metal. I does softed plastic. I use a hot glue gun on the screw threads, if in a bind. Purchase a diff housing as Team Kamakazi suggest. Useing CA you definitely purchase a new diff housing after a while. Try putting nail polish on the screw & plastic, if its cracked, its loose.
#3449
I have seen this happen several times, it happened to me causing the diff to seize.
As this is metal to metal, loctitie is the fix.
See photo of what I am talking about...
