Serpent 733 1/10 200mm touring
#2611
Nope, LiFe. I never had a NiMh in the 733.
Started with the 1300 mh Life and then tried to shave some weight with a 1500 Lipo and the regulator.
I run the same setup in my son's 966, but he has enough room to mount that regulator under the low profile throttle servo. there it has enough cooling to work fine.
#2612
It might not be the right charger for electric raing, but for our TX, RX, glow ignitor and starter boxes it's perfect.
Cost me €35 incl. s/h from China.
Charge you soon....
#2613
I have an IP 72 grams 1450mAh LiFe Rx battery in my 966, car weights with empty fuel tank and worn tyres (how you finish a race) 2510 grams.... which I believe is quite perfect (2500 is in our regulations)
I have the Turnigy accucell, costs $25,- nowadays I believe, and do use it also for indoor M18 racing...
I see this charger also being used for 1/10 and 1/12, so it is good enough, also for racing.....
#2615
Ok, clear. Just wanted to be sure, but I know you know your stuff, but still was wondering... my bad..
I have an IP 72 grams 1450mAh LiFe Rx battery in my 966, car weights with empty fuel tank and worn tyres (how you finish a race) 2510 grams.... which I believe is quite perfect (2500 is in our regulations)..
I had to raise the tank a bit and then the throttle linkage would rub the tank.
You wouldn't know how high that IP LiFe is?
Cheers.
#2616
I can lower the tank by 2mm if I need to....
This is the one I've ordered:
http://www.rc-mushroom.com/product_i...ducts_id=18240
I've gleud it on the closed carbon battery plate, so no tape needed....
Will make a picture tonight, when I am home....
I will post it in the 966 thread then.
BTW, to bad it isn't Holland - Germany in the final....
#2617
EDIT: i applied a bit of logic into a google search.. orange 27mm spring part no. is 160322.. dont believe i didnt work that one out earlier! *doh*
#2620
i Believe he means the 27mm orange and pink springs.. the part no. for the pink springs is 160324.. i have been looking for the 27mm organge spring part no. aswell but not having much success.. the red spring is the softest 27mm spring i can find on the serpent website?
160320 - White 2.3/13
160321 - Yellow 2.8/16
160322 - orange 3.4/19.5 then the rest you can find ont he serpent site under optionals for the 966
#2621
awsome thanks guys!
#2622
#2623
#2624
Lateral play on gearbox shaft
Hi,
I am new to this thread. I recently changed the 54T 2 speed gear (part 803222) and the one way bearing (part 902411) on my 733 and now I notice that the gearbox has some lateral play on the gearbox shaft (about 1mm I think). Looks like the replacement 54T is somehow a fraction narrower then the original one. The shim (part 9638) normally removes the play but now it doesn't remove all of it. What should I do?
Thanks for any advice,
Frank.
Frank.
#2625
Hi,
Frank.
Frank.
