Serpent 733 1/10 200mm touring
#1726
#1728
The http://www.serpent.com/product/802354/ 2x9,8 square ended pins go in the wheel axle side of the cvds. You must use this pin as the rounded edge http://www.serpent.com/product/1109/ pins (used in the bodymounts will have less contact area in the wheelaxle leading to premature wear.
For the diff side pins you'll need http://www.serpent.com/product/1113/ or part#801322 (same pin just 8 pcs)
#1729
#1730
#1731
#1732
Xceed New Product
XS Clutch 1/10 with Serpent Bell
Flywheel 30mm
Flywheel 30mm
#1734
Not sure that there is one for the serpent. I think it may be to use with other cars, since it seems the other cars are trying to work their way to the serpent clutch anyways. This will allow you to use the serpent parts on other brands.
But this is just my guess, I have not been told anything by Xceed. I am just going off the picture posted.
DJ Apolaro
DJ Apolaro
#1735
Sirio Engine on 733 fitting tuned pipe problem
Hi Guys anybody out there running a Sirio engine on the 733, did you have any difficulties fitting in the tuned pipe? The one we have is too long and touches the front steering arm. On the Velox V10 it fits since the engine is mounted more towards the rear.
Any help would be appreicated.
#1736
Got a photo? Maybe that will prompt some other ideas...
#1737
Anyone read this?
http://www.serpent.com/news/12891/Se...10-season.html
New material suspension parts better release quick...
#1738
Anyone read this?
#1740
The pipe is in fact the 2611 any idea what other pipe is available from sirio?
