kyosho strr center diff >
Old 06-05-2009, 08:21 PM
hobdog's Avatar
Trader Rating: 19 (100%+)
Default kyosho strr center diff
I am just curious if anyone has ran a kyosho strr center diff and spur gear on a jammin x2 before. I am wondering if it works? I am looking at changing my gearing a bit, but switching to a 14 tooth clutch bell may be to much, and I need a new center dif anyways. I have better line on a kyosho than a jammin, and I think a 50 tooth spur with a 14 spur might be better gearing for my mill.
hobdog is offline
Old 06-05-2009, 08:51 PM
motomanpat's Avatar
When I had my X1 with the BCE and a 528 with way too much power I was running I think 46 16 and it felt better after I did that. I was running a Kyosho spur I am pretty sure. I also had the Hot bodies spiral ring and pinions so it may be a bit different than your setup. I will look up the info tonight after I get off work and let you know. I know that I used Jammin buggy center diff posts though. Also you can look at truggyracers.com under the CRT thread or delve around the BCE chassis thread.
motomanpat is offline
