Does a rear skid plate mess with handling?
Just wondering since I put on the de skid I raised the ride height to set it under the skid. So now my cg is higher, also a local pro said he seen my rear bouncing from the skid hitting. So what is your take on this?
i run the de skid on my 8t 2.0. its 3mm thick. so when i messure from the bottom of the plate i set the gauage 3mm lower then the actual rh. so on my truck the front should b 39mm and the back 42mm. so i set the front and the back the same height messuring from the chassis in the front and from the sd
kid on the back.
kid on the back.
kid on the back.
kid on the back.
