Transmission illegal for 1/8 scale buggy and truggy?
I did. This is the section I found for ROAR:
8.10.11.4 Transmission and drive:
Single speed transmissions only
4WD
RC Pro series says basically the same thing, though, there electric 1/8 arena truck rules (not electric 1/8 buggy however) say:
Transmission/diff - - - - - - - - - - - - - - - - - - Single speed direct drive (1/8 buggy) style driveline only.
My understanding then would be a as long as its single speed, a tranny could be used?
4WD
Tech Prophet
4WD
4WD
a center diff is not a single speed transmission, its a center diff. Transmissions have some sort of gear reduction, the RC10T and B are a good example of a single speed transmission.
the direct drive part is the killer.to me that says pinion/spur only.
The direct drive part doesn't really make any sense. Direct drive would infer that there is no reduction at all, that the motor is connected directly to the drive axle. The gearing on a 1/8 scale is reduced at the clutch/spur and again at the pinion/ring gears.
