Pipe for mu Picco Evo3 .21
I need to know pipe is best suited for Evo3 .21 in my Jammin x1 buggy?
JP-3?
JP-2?
Dyn. 086?
Tyler
JP-3?
JP-2?
Dyn. 086?
Tyler
These two pipes will fit that engine nicely. The Picco 21's have the exhaust pointed down a bit. The manifolds included with these two pipes are made to fit those engines.
http://www.amainhobbies.com/product_...ducts_id/18700
http://www.amainhobbies.com/product_...ducts_id/18701
Both those pipe's SUCK WIND on the picco's......the header's may fit nicely but they do not perform very well on them from what ive tested....Granted my motor's aren't stock...but that wont matter in the end.
Gearhead racer....go with the cheeper Dynamite 086 for now and when you got some extra $$ then start investing in different pipe's.....Jp's work..but imo the 086 is that much better.
I have Picco 21 EVO2 yes the outlet points down some. You do not need too get any of the manifold above. It's very easy to bend the manifold to fit I did this to my JP3. If you want to get them thats up to you.
re
the 2013 pipe works very well the jp-4 will tame the bottoma bit
When I ran the Piccos I alternated between the Ofna 053 and the Ofna 086. It's like having two motors with these pipes. The 086 will have a smoother delivery with a little more top end for big/slick tracks. The 053 makes the motor an animal. It still has really good top end with a lot of torque and makes pretty good mileage too. I ran the 053 the most. You can make any header work on the Picco. Just heat the manifold up with a propane or mapp gas torch and twist it with two pairs of vice grips.
I ran the Drake pipe on the Evo 2 and thought it was awesome. The only downfall was that long stinger was easily bent. Its a perfect fit and the gaskets last a lot longer because of it.
hum.... I think i mite be getting a 086 Dyn.
I ran the JP3 for years & loved the power then finnaly went back to a 086(dyn this time) & just deal with the loss of low end.086 feels real slow on the bottom compaired to the JP3 but gets like 1.5-2 min longer run per buggy tank depending on how you like to tune.086 also has better ish top if you have long tracks,I dont.I had to drive differnt but 1 less pit is about worth it & cheap to try,$35 hard coat on sale at B-main.But I assume you listed the pipes because you had them already?I didnt like the JP2 that much,no bottom compared to 3 & no run time compared to 086.
I have the dyn .086 version just haven't tried it yet. The only reason why I have stuck with JP series pipes because of the stronger stringer
