Tune pipe for Jammin x2 truggy rtr
Need suggestions of pipes i can use with the factory motor in my jammin x2 rtr which is a ofna force 28 7port. I currently run on my personnel track (88x158, two straight always about 110 and is pretty technical in some areas)and this summer ill racing at a local track which is desgined pretty close to Nitro Pit in AZ http://www.youtube.com/watch?v=3oc_2Q2Wk5w. thanks
Ty
Ty
get a JP3. It works with everything.
I have ran the JP3 pipe with a force 28 engine a few years ago and it made a huge improvement on the force.
Any ideas???
With the stock motor use the JP-3 pipe.
I currently run A dyn 053 on a GRP.21 engine and it works good. But not sure how it runs with a force. I would probably get an all around pipe. Like the JP3. The force engine is not going to last you to long anyhow. The nipple on the end of the crank likes to break. Once the crank goes it isn't worth fixing.
does the jammin x2 RTR come with the fuel filter and fuel filter clip on the fuel tank or it only comes with the pro kit?
