Novarossi engines thread
#3781
Trader Rating: 13 (100%+)
#3782
I'm using the Capricorn plugs in all my Nova engines since the GRP plug quality went to crap as well (just like Nova).
The Sirio based plugs last a lot longer and make a bit more topend power compared to a nova plug.
#3783
Plug Question For DS
[QUOTE=DS Motorsport;8273990]Get some Sirio based plugs,
Hi DS
I don't own a Sirio motor but I know the sirio button is a different shape (slight tapper difference) to the nova's & the bottom of the sirio & nova plugs replicate this to correspond to there respective button chamber.
With this in mind would it still be ok to use Sirio plugs in nova engines as I too need plugs & the sirio plugs are much easier for me to obtain.
Also your capricorn lab looks awesome DS
Cheers Daz
Hi DS
Cheers Daz
#3784
[QUOTE=Jazza;8277430]
Hi Daz,
I haven't seen a sirio button op close, but for my Lab engines I informed with Capricorn which plugs they recommend and they recommended the Capricorn plugs, which are Sirio plugs. So don't think there is a problem in terms of fit or taper, also the Nova button doesn't look damaged or anything.
Thanks man, for 2011 it's going to look even better.
Hi DS
Cheers Daz
Hi DS
Cheers Daz
#3785
I've got my 353ct in and ready to run, 25 degrees outside and six inches of snow on the ground.
I'm going to need a connecting rod for this motor when it drops its nuts, anybody know where I can pick one up on the west coast?
I'm very impressed with this motor and my hats off to Novarossi.
#3786
What's the difference between the Novarosi pipes EFRA 2660 and EFRA 2652 1/10 on-road?
Thenks
Thenks
#3787
Crank and rod needed n12ll5
looking for a good used crank and rod or new parts
crank #15605
rod #07601
Is this max power crank the same as the ll5 it uses the same novarossi numbers?
www . rcmaxpower.com/en/products/dwn.asp?file=138.pdf
take spaces out
crank #15605
rod #07601
take spaces out
#3789
35PLUS21LC/WC09
hi guys
does NR 35PLUS21LC/WC09 came with manifold
thanks in advised
thanks in advised
#3790
X'Mas Sale now !
#3792
The midrange needle has the same effect als the low speed needle.
The only difference is that it will move the spray nozzle within the airflow so you can tune it a bit to optimze the position of the spray nozzle at a certain opening of the carburator.
#3794
Flush
