Like Tree195Likes
Novarossi engines thread
Old 02-05-2010, 04:24 AM
  #3406
Default Nova pistons
Hi there,
the hype about a CNC piston for the 2010 Flash is confusing to me. Since I am in the on-road hobby Novarossi is changing back and forth between piston manufacturing processes. I don't see that on or the other is clear winner.
Any one has some thoughts or insight regarding this?
Thanks a lot and best regards, Stefan
fulcrum2 is offline
Old 02-06-2010, 01:53 PM
  #3407
SMcpot's Avatar
Trader Rating: 22 (100%+)
Questions??
Getting back into nitro after a few years and wanted to know what the consensus is on the O'Donnell turbo plugs and fuel? I'll be running these in an NS12S3 and RX21R1WC.
(don't laugh, they're brand new!)
SMcpot is offline
Old 02-06-2010, 06:32 PM
  #3408
JRGTR's Avatar
i am planing to buy one of the new novas, i run max pwr engines but i like to test one of the new novarossi engines, can someone tell my the diffrence os the .12 flash 2010 and the new353 2010?
thanks for the feedback!
JRGTR is offline
Old 02-06-2010, 08:20 PM
  #3409
Team Kamikaze's Avatar
353 are only available in stock versions either with Ceramic or regular bearing, while the Flash 12 3 comes in factory modified only.
So for 2010, the Flash 12 3 is now the Flagship engine for the .12, while the 353 is their secondary engine line.
Team Kamikaze is offline
Old 02-06-2010, 08:47 PM
  #3410
wingracer's Avatar
Trader Rating: 24 (100%+)
The fuel is excellent, probably my second favorite after Maxy. I have never tried the plugs but I hear they are good. I like Sirio plugs for Nova motors. And that R1 is nothing to laugh at. Still one of the best .21's out there.
wingracer is offline
Old 02-07-2010, 08:14 AM
  #3411
asw7576's Avatar
How to break in again after p/s/r replacement ?
How do you do heat cycle ? Does it save fuel and time in the process?
asw7576 is offline
Old 02-07-2010, 11:33 AM
  #3412
Trader Rating: 21 (100%+)
There is not much diffrence between the flash 12 and the 353 09 lookin at the exploded view. Its hard to tell unless you look at the parts side by side. but most of the parts have the same part number.
VA_Racer is offline
Old 02-07-2010, 01:24 PM
  #3413
JRGTR's Avatar
I saw a few pictures and the crankshaft and sleeve loks diffrent so I'll go for the flash! thanks for the info and feedback!
JRGTR is offline
Old 02-07-2010, 01:43 PM
  #3414
The crankshaft, rod and piston are the same as the 353 09
VA_Racer is offline
Old 02-08-2010, 09:49 AM
  #3415
SMcpot's Avatar
Thumbs up
Thanks, wingracer.
SMcpot is offline
Old 02-11-2010, 11:02 AM
  #3416
cheROK1212's Avatar
Trader Rating: 13 (100%+)
Any idea when these r coming in, I tried to buy a 353 but ran into inventory issues
cheROK1212 is offline
Old 02-11-2010, 03:06 PM
  #3417
Roelof's Avatar
Originally Posted by fulcrum2
Hi there,
Do you know tje difference if you have the 2 pistons in your hand?
I do not believe so.....
Finally both pistons are CNC made because there is no way you can get a piston out of a mold in a perfectly fitting shape.
But all is about the material, microcasted will give a stronger material but the Flash did had some bad pistons last year so in a commercial story they tell you they changed materials. Let me tell you if you are depending on different suppliers then there is always a change in materials and you will only notice is in the way how the pinch feels and how fast it is runned in.
Roelof is offline
Old 02-12-2010, 12:23 AM
  #3418
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
is there any difference in plus 12 cst 09 compared to there older 07 and 08 versions
Alex Siddique is offline
Old 02-12-2010, 07:32 PM
  #3419
JRGTR's Avatar
i just pick up my new flash .12, one of my teamates purchase the new 353 , we opnen our engines ans surprise! the flash crankshaft have a lot of work and loks awsome! the 353 look more stock version and the con rods have diffrent numbers the 353 have N1 and the flash conrod have N2 number. any answer for that???
JRGTR is offline
Old 02-13-2010, 12:03 AM
  #3420
Serpent-Dan's Avatar
Trader Rating: 18 (100%+)
It would be nice if you posted pics of the two cranks
Serpent-Dan is offline
