Novarossi engines thread
#2821
Well I currently run the 2630 with the short manifold and I also have a no name pipe and manifold that looks alot like the RB pipe mentioned so I will do some test this weekend and see what I find. I am thinking to get another 2630 and a 2601 both Novarossi pipes. as they seem to be what everyone is talking about with power and fuel being the idea's.
#2822
I have been getting 7.5 minutes of run time with my NS12 TS1 at our club races.
Motor has great power also. Bottom end is good, but not like a more expensive mod motor and such.
I love the thing. For the price you can't beat it.
We run on a parking lot track with soda pop for traction compound.
Kyosho RRR WC with RD Logics Pipe.
#2823
the is not so much power in them as the is in the 2630
but more runtime.
#2824
I just got my first novarossi engine it's a 35plus cordoba.When I started looking at it I noticed it has flathead screws holding the backplate and headbutton on.I hate flathead screws and have no idea why novarossi does this.Anybody ever change them for hex heads?Also the motor has a three speed carb.How do these three needle carbs tune up?
#2825
Yes you can replace the screws.
The three needle carb is no different than any other carb if you leave the third one alone. The third one being the spray bar (usually called a midrange needle). It really does not need to be adjusted and is best left alone unless you really know how to do it.
#2827
Ordered the screw kit today.Thanks
#2828
hi there i've being thinking about getting a max xxl3, i already asked in the max xxl3 thread and they said that the max was the best one even against the novarossi 3sct or 353, maybe they right, since the xxl3 it's a novarossi based one, but isn't it the 353 or 3sct with more advanced technologi than the xxl3. from what i've heard the engine manufacturer presume about their long stroke, from that point of view the 353 and the 3sct have longer stroke so i think that makes a better engine to those pure novarossi.
#2829
no really go for a novarossi, there is more technology in the nova engines, and also the max looks like it has a nova shaft but different sleeve, and again the novarossis sleeves look better
#2830
hey what differences will i see from the 353 tuned and the 3sct tuned?? which one is faster??
#2831
The Max engines are based on Novarossi engines and are produced by Novarossi.
The MF versions are then modified by Massimo Fantini.
#2832
and where are they compared to the pure novarossi engines? i mean xxl>= to what?
#2834
thanks for ur replies Sam, it seams to be a solid winner.
#2835
head clearance for 353
anyone know whats the actual head clearance for a 353? is it the same as the 3sct, ie 0.3mm + 0.3mm?
if thats the case, it should be safe to not add anymore shims for 25% nitro right? even if you add 0.1mm of shimming, isnt it a bit too much, ie 0.7mm? top end will suffer?
