Novarossi engines thread
#2266
Timing data needed
Hi:
I need some timing data from a pair of Nova engines, let's see if someone has them (or at least one of those two) and could make me the favor of degreeing them. Need the timing data of a Nova P5X and the timing of a Plus 21-7 (all two are off-road engines).
Thanks in advance.
Thanks in advance.
#2268
I am trying to find a suitable replacement p/s set for my RS12S1X
The novarossi page says the replacement part # is 08604
I found an 08601 and a 08614 .
Will these fit ok? I am thinking that any .12 non-turbo set would be ok, but the porting may be different?? Can anyone confirm this?
The 08614 is from the-border.com, the picture is of a 5 port but the description and part number are for 3p. Their seems to be no way of contacting them through email as their 'contact us' link doesnt work, and I dont want to call them because of long distance. There is also a language barrier, I live in Canada. The site is in the Netherlands.
#2269
you can contact [email protected] for more info.
thank you
#2270
Hey johnny i think the problem is not the ceramics but the high speed needle orings. Could it be that the needle is richening its self because the orings r damaged?
#2271
I already tried changing orings and other
leaks from the fuel line. I still got the same problem. But when I changed
the bearings from ceramic to steel, the tune became consistent.
#2272
#2273
mabee the bearing is stuffed?
#2275
Check that front bearing has the front shield ok, is correctly seated and you do not have airleaks on the engine.
#2276
could someone help me out, im looking for the stock needle settings for the old Novarossi MT12 engines
#2277
.12 engines + 30% + 7Tf : 0.3 + 0.1 ( risky ); 0.3 + 0.2 ( safe ); 0.3 + 0.3 ( very safe )
.21 engines + 30% + 7Tf : 0.3 + 0.1 ( quite safe ); 0.3 + 0.2 ( safe ); 0.3 + 0.3 ( very safe ).
0.3 is original shim ( silver ).
Pick your cards .........
I prefer very safe rather than getting a melting coil situation.,,,,,,,, sucks man !!!
tks
#2278
does anyone know what piston and sleeve I can use on the ns12p(practice motor from the 353 package)the parts breakdown show part #08604 for sleeve and piston but I cant find this part anywere.
Also whats the verdict on the 353 I am getting ready to break it in and am wondering how it performs
#2279
Regarding the p/s for the practice engine. I would contact fusion motorsports as to what will interchange with that. That part number is not a current part number in the May 2007 novarossi catalog. I bet you will be able to use the 08606 or 08608. The 08606 is for the NS12S3. The 08608 is for the NSR12S3 (microcast). Those two part numbers are still current.
